AH FabricationsChris Nott
    codrock's Avatar
    Nov 2008
    45
    replacing bulb in centre brake light.......is it straight forward
    ive just realised my centre brake light isn't working what are they like for replacing??
    Should it have shown up as a fault when ignition is turned on??
    Fossie
    Rhubarb Triangle
    3,961
    I would have thought it should show a fault !
    codrock's Avatar
    Nov 2008
    45
    no-one changed one before??
    Fossie
    Rhubarb Triangle
    3,961
    Just remembered the high level brake light is LED and therefore is most unlikely to stop working altogether.
    Much more likely that the connector or some part of the wiring has come loose/been damaged somehow.
    I think you can remove the rear portion of the headlining to get at it. Check if there is voltage at the connector - if not then it's the wiring somewhere.
    Aug 2008
    408
    the plastic trim on the inside of the tailgate must be removed to gain access to high level light, as mike has said its led in design, and if all electrical connections are ok, the unit will need replaced etc, hth
    cal
  1. replaced bulb and now brake lights stuck on !?
    By stu_b in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2011, 23:04
  2. Changing centre brake light on A4 Cabriolet
    By sva19 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th December 2009, 12:46
  3. Centre brake light bulb replacement
    By JohnC in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd December 2006, 21:54
  4. Centre Brake Light
    By cs_horn in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th July 2006, 18:29
  5. centre brake light access
    By MickA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2005, 16:35
