Monster MotorsportEM Tuning
    Roady's Avatar
    Nov 2010
    Hereford
    42
    Brake warning light AFTER fitting new pads & MOT, no warning with worn pads!
    Had my '06 Audi A3 2.0 TDI Quattro Sport serviced and MOT'd yesterday. Knew my front pads were **very** worn (tried to change them myself but was sent the wrong parts) so asked the guy to change them aswell.
    Previously I hadn't had any warning lights regarding the pads being worn... Nor the rears (which were replaced a month or 2 ago).
    Now after the change and MOT my car's warning me that the brake pads are worn! I can clearly see the new pads are fitted correctly and have plenty of tread on them... So my question is:
    Can the signal cable/sensor wire be incorrectly plugged in/setup? Giving me a false positive and nothing for a true negative?
    Darkside Warrior! (Diesel) & former Focus (FFOC) nut
    Current ride: Audi A3 '06 2.0TDI Quattro
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    I've not checked how Audi works, but generally the wire needs to be earthed (against the disc) for the light to come on. A split pin can bridge them to test the light.
    So they can be left unplugged without issue.
    Some, work opposite though, I done a jag years ago which put the light on if unplugged.
    It's not impossible they messed it up, maybe broke the wire off the pad, or pinched the loom etc.
    Take it back, they fitted them, so it's down to them.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    Roady's Avatar
    Nov 2010
    Hereford
    42
    Ok thanks Rom
    Havn't yet spoke to the guy (will today) and see when he can sort... May sort it myself as driving to the airport saturday and not back for over a week! :D
  1. First start after fitting new turbo.
    By markthenewt in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2011, 19:52
  2. Problem after fitting new cat
    By audiv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2011, 21:05
  3. Brake pad warning light reset???????
    By 46TheDoctor in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th April 2007, 08:27
  4. New brake pads fitted - Warning lights
    By Matty-K in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2007, 14:54
  5. Brake Warning Light After Brake Pad Change
    By iddyarmin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th May 2006, 20:47
Tags for this Thread
