Sky InsuranceBadger5
Thread: Cruise control
    May 2012
    23
    Cruise control
    The A3 S-Line that I test drove last week said it had cruise control in the advert but I couldn't work out where it was. Should it be a small stalk under the indicator stalk. If so it didn't have cruise control. Not that fussed if it doesn't - or should I be?!? :D
    H88
    H88's Avatar
    Apr 2012
    Lewisham/London
    232
    Dealer may made a mistake. Same as my when I read the advert,it says it has got cruise control but when I bough the car it didnt have it. I forgot to check when I bough as I was too excited,only realised my mistake after I got it. If the car has got cruise control,it should be on the left under the steering wheel...it should look like indicator stalk )
    Fossie
    Rhubarb Triangle
    3,969
    Yes - it's a small stalk under the indicator stalk.
    You don't say what year it is and I'm presuming the CC system is still the same as it always was but if the advert and blurb says CC you should ask them where it is !
    If you're interested in buying then insist CC is fitted as per the advert.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,099
    Hi mate, if it does not have cruise, insist they give you the money to get it done, and if so, then I can install for you using genuine brand new parts if your in or around London.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    May 2012
    23
    No it definately didn't have the stalk. It's a 2008 08 reg.
  1. cruise control retro-fit
    By yoda01 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th June 2010, 15:11
  2. CRUISE CONTROL, CAN IT BE DONE?
    By blackwood in forum General Technical / How To
    Last Post: 2nd October 2004, 15:20
  3. Retro fitting cruise control
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2004, 10:35
  4. Cruise Control,
    By t955daytona in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2003, 20:45
  5. Retrofit Cruise Control
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:08
