Volks AutosAH Fabrications
Results 1 to 10 of 10
    TimJK's Avatar
    May 2011
    Norwich, Norfolk, United Kingdom
    356
    Turbo back exhaust fitted, safe to up boost?
    Had my car mapped revo stage 1 the other month, settings;
    Boost 6
    Timing 5
    Fueling 9
    Already had an itg intake and forge recirc valve fitted before map.
    Now I have just fitted a turbo back milltek exhaust.
    A friend has an sps switch so wandering if worth upping the boost now the exhaust can flow more. Safe to do so?
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,619
    Do the fuel pump internals if you havent already.
    isn't your fuelling pretty high?
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    TimJK's Avatar
    May 2011
    356
    I'm running vpower 99, mapper said that's running spot on but now I've got an exhaust fitted I'm wandering can I play with the boost.
    Hpfp is the next thing I want to do the get a stage 2 map.
    For now though just wandering what's safe to increase.
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,619
    did some homework on your fuelling. 9 is normal for high octane.
    i think people have tried - boost 6, timing 6, fuelling 9. with positive results.
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,619
    I think to be honest, the HPFP should be first on everyone's mod list. You don't have to worry about starvation etc.
    i think you should leave it as it is, buy the pump internals, then fiddle. last thing you want is it running too lean. and revo has had this problem at stage 1 on some cars.
    TimJK's Avatar
    May 2011
    356
    Ok so that just timing advance then. Not sure my mate has vcds so maybe not wise to try B7 T6 F9
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,619
    ps IGNORE STAGE 2. theres very little in stage 1+2. All you need now is the HPFP. stage 2+ is the next stop.
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,619
    you'll save £50 which can go towards the pump.
    Im currently stage 2 shark. I wish I'd just gone straight to stage 2+. it's £100 per upgrade with shark too!!
    TimJK's Avatar
    May 2011
    356
    Stage 2+ is more than just a hpfp though. Most likely clutch, intercooler too.
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,619
    oh if your manual yep, I predict you'll need a new clutch at stage 1 in about 1k time!
    intercooler isn't necessary. The edition 30 mk5's originally have a smaller one than ours and upgrade to ours when they go stage 2+. it's perfectly fine. (exactly the same engine as ours) Yes you could twintercooler it. But it's not necessary at all really.
    anything above stage 2+ I could understand.
  1. Lost a little boost after fitting turbo back exhaust
    By Inertiauk in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2011, 14:01
  2. XS Power turbo back Exhaust system with 3" DP fitted :)
    By Nez in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th October 2010, 10:57
  3. MV Sport turbo back exhaust system S3 2.0TFSi
    By warren_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2010, 14:10
  4. Custom turbo back exhaust
    By S3 Nattie in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2009, 10:49
  5. turbo back exhaust
    By nick-barnes07 in forum Awesome GTI
    Last Post: 7th June 2007, 12:02
