Chris NottSky Insurance
Results 1 to 38 of 38
Like Tree6Likes
  • 1 Post By Sandra
  • 1 Post By Sandra
  • 1 Post By mike foster
  • 1 Post By Sandra
  • 2 Post By Dannykn9
Thread: Retrofit cruise control problems help
    Apr 2011
    26
    Hello!
    I bought the 8P0 054 690 cruise control kit for my 2005 A3 3-door, no singleframe.
    I have fitted the cc and tried the coding in vagcom. And the ecu have accepted the CC. But it still does not work.
    I have tried desperately to find the blue connector for the extra wiring that came with the kit, but i can not find it. Been looking for hours.
    The connector 13 already had a wire going into it. Is that correct?
    I have the 953 549F.
    Can somebody please help me what to try next?
    Fossie
    Rhubarb Triangle
    3,961
    Have you coded steering and engine control modules ?
    Not sure what you mean by 'no singleframe'
    Apr 2011
    26
    I'm so sorry....we did a mistake.
    We took the test drives with vagcom still connected to the car. And then it would not work. But as soon as we removed it, it works
    Funny thing is the set button and resume function does not work. Only off and when i push it up or down deploys.
    Any idea why?
    Fossie
    Rhubarb Triangle
    3,961
    Sounds like you have steering module version that starts 1K0 not 8P0. I had this with my first module and if I remember correctly your CC operates in the 'alternative' mode as follows :-
    When the stalk is pushed fully away from you it is 'OFF'
    Pull the stalk towards you until it clicks and it is 'ON'
    When driving flick the stalk towards you to 'ARM' the system and then flick downwards to set speed when ready
    Whilst CC is set then push up to increase speed or down to decrease speed
    To disengage CC flick stalk away from you (or press brake or clutch pedal)
    To 'RESUME' flick stalk downwards
    The 'SET' button does not operate at all with that steering module.
    It is quite easy to get used to and operates in a quite logical manner when driving.
    Apr 2011
    26
    That's what i figured out to Right now i'm just glad it works.
    It's not worth the hassle to change the steering module for that?
    Thank you for your help
    Apr 2011
    26
    Do you by any chance know what i have to do to make it work properly?
    Now that i know this i need to get it right
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by flippin82 View Post
    You said in post#5 that it's not worth the hassle to change steering module.
    Unfortunately you will need to get a 'Highline' steering module. Yours is a 'Midline'
    There is no way to make it work how you want it to without changing the module - sorry.
    Apr 2011
    26
    I know, but i had worked on it 6 hours so i was just glad it worked
    But now i'm ready to go again, and i really want it to work proper.
    Do you know what part number of that steering module? And that's all i need to do? No other parts?
    Fossie
    Rhubarb Triangle
    3,961
    8P0 953 549 F - approx (£170 from Audi) or you might be lucky to find one on ebay for about £100.
    No other parts are needed.
    Should be able to change over in about 30 - 45 minutes but if it took 6 hours for you to do it first time then it might take longer.
    Apr 2011
    26
    No the whole job was actually done in about 1 hour. But the only mistake i did was to not unplug the computer and vagcom, so when i went for a test drive it did not work. so i spent 6 hours looking for the blue connector, because i recon that was the only thing missing. But i was proven wrong
    I think i have the 8P0 953 549 F. Not to say sure, but there is no other reason for it to be working in alternative mode right?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,291
    Think Danny k9 has that module still up for sale.
    Classifieds: A3 8P Steering ECU module "F" plus other bits!!
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Apr 2011
    26
    Quote Originally Posted by Sandra View Post
    Extremely thankful for that Sandra :D
    Fossie
    Rhubarb Triangle
    3,961
    You have got 1K0 953 549 F. It is not the same as 8P0 953 549 F. If you had the 8P0 version and coded it correctly then it would work as planned.
    Where are you based ?
    Apr 2011
    26
    I'm from Norway. I believe you are correct about that. So i need to get hold of a new steering module
    Fossie
    Rhubarb Triangle
    3,961
    Norway is a bit too far to travel to try and help you out but I'm sure if you get the new control module you will have it fixed very quickly.!!
    Good luck and let us all know how you get on.
    Apr 2011
    26
    But you have given me all the help i need, and i'm really grateful for that! This is by far the best forum.
    I checked the prints in vagcom, and i have the 1K0. So hopefully i'll get hold of danny's module
    I will let you know how it goes
    Apr 2011
    26
    Just one more question The slip ring can stay as it is right? Don't need to change that too?
    Fossie
    Rhubarb Triangle
    3,961
    Slip ring is ok. Check on vagcom - it should have suffix 'D' which is right.
    Apr 2011
    26
    It is a 3-door btw. In etka the F is for 4-door. That does not matter?
    Fossie
    Rhubarb Triangle
    3,961
    Same for 3 dr and sportback. Trust me, that module is all you need to fix it !
    Apr 2011
    26
    Ok i trust you It's just my fellow mechanic who says my slip ring suffix C in etka, and that it is only for 4-door the F module Hope Danny's still up for sale so we'll find out quick
    Fossie
    Rhubarb Triangle
    3,961
    What slip ring do you have ?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,291
    I have checked the classifieds, he still has module listed for sale. x
    flippin82 likes this.
    Apr 2011
    26
    That i did not know
    But you are right. Since the slip ring D goes with the module F and slip ring C goes with module J, and i have module 1K0 953 549 F. So if i have 1K0 or 8P0 slip ring with suffix D it will still work? Don't need the slip ring to be 8P0 to?
    Fossie
    Rhubarb Triangle
    3,961
    You have the correct slip ring - ignore your mechanic !! 'C' or 'D' will be ok.
    Is the sun still out up there ?
    Apr 2011
    26
    He's bit of a etka slave I'm sure this will be all good if i get Dannys module
  28. #27
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,291
    Trust Mike, he knows what he is talking about. x
  29. #28
    Apr 2011
    26
    I trust him
  30. #29
    Fossie
    Rhubarb Triangle
    3,961
    There are plenty of threads on here to help you - just search for cruise control.
    Make sure you tape the slip ring together after you have removed the steering wheel because if it moves position when you remove it it can be quite complicated to get it re-aligned.
    By the way I am speaking from experience because this is everything I had to do previously, firstly to fit CC and then to fit mfsw !
    Sandra likes this.
  31. #30
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,291
    ​Danny is going to pm you. night folks. Will catch up with the progress on here tmrw. x
  32. #31
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    Hi mate, have sent you a PM.
    Mike is 100% correct!!
    I also have the slip ring "D" for sale.
    Thankyou Sandra, much appreciated :-)
    Sandra and flippin82 like this.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  33. #32
    Apr 2011
    26
    That's where the mechanic comes in handy Danny had it and i'll buy it from him. It all works out quite easy now
  34. #33
    Apr 2011
    26
    Sorry for this, but what is mfsw? Norwegian you know
  35. #34
    Apr 2011
    26
    Is the sun still out up there ?[/QUOTE]
    We've had the best weather ever 26C and blue skyes and me celebrating my 30th birthday on sunday Perfect!
  36. #35
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,291
    ​Mfsw is multi function steering wheel. x
  37. #36
    Apr 2011
    26
    Aaaaaaah
  38. #37
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    And with the new module you are buying of me Andreas, this will also allow you to upgrade to a MFSW at a later date :-)
  39. #38
    Apr 2011
    26
    Hello again!
    There is a new problem....since i have the old steering wheel, danny's module and slip ring is for a dual stage airbag, and i have a single stage. What options do i now have to makes this cruise control work properly? Is there no other slip ring that will work? Now i don't have powersteering,esp or stereo :/
  1. Please help cruise control problem 8P
    By Troubs12 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2009, 22:58
  2. HELP Retrofitting cruise control, need VAG-com can in south west UK
    By Dannyboyski in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th February 2006, 21:03
  3. retrofitting cruise control?
    By Strick in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th June 2005, 23:38
  4. Calling people with cruise control!!!! Please help
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th September 2004, 01:29
  5. Retrofit Cruise Control
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 16:08
