Volks AutosAH Fabrications
    Jan 2012
    Aberdeenshire
    51
    Creaking Clutch Pedal
    Wondering if there is an easy cure for this or indeed if its likely to be considered under warrant, I've a 59 plate S3 sportback and with the warmer weather we've been having I've noticed my clutch pedal makes a noticeable creak / squeek just at the top point of travel and its driving me crazy.
    Also there is a hell of a creak on cold days from the plastic trim somewhere around the hand brake - anyone had this and what have you done? I've temporarily silenced it by shoving a thick cloth down beside the passenger seat and the centre console but this is far from ideal.
    Mar 2008
    Do what the garage would do.........silicone spray! just don't over do it and wipe up any excess. Can't be too carefull with the pedals!!!
    2004 A3 3.2 Quattro Sport DSG S-line
    2008 KTM 950 Supermoto
    1988 Honda CBR400RR Tri-Arm
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Is it inside the car, or under the bonnet?
    Master cylinders (end if the pedal) can creak, seals dry up.
    Slaves (on box) can do the same, as can the bearing on the shaft itself etc.
    Need to confirm where it's from. Should do it with engine off, and all the time if so.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    Jan 2012
    Aberdeenshire
    51
    It seems to be more temperature dependant than anything. I would say its coming from inside the car and does it with the engine on or off. Warm = creak, just at the top of travel. Barely have to brush the pedal to make the noise. I think the stealer will be getting a call then, could be more serious than i first thought...
  1. Clutch Pedal - Stuck
    By necroeire in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2005, 20:04
  2. Clutch pedal sticking
    By monty77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2005, 14:58
  3. Creaking clutch
    By marctwo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2005, 16:45
  4. clutch pedal vibrating
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th September 2004, 21:12
  5. 1.9 TDI Serious Clutch Pedal Vibration
    By matt_splatt in forum General Technical / How To
    Last Post: 13th April 2004, 22:53
