Sky InsuranceVolks Autos
Results 1 to 12 of 12
Thread: Squeaky belt
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Squeaky belt
    Chaps
    Car is an Audi A3 8P 2.0 tdi 140
    Since yesterday I have noticed my engine squeaking loudly at times.
    It sounds like a fan belt slipping? But I assume we dont have fan belts anymore?
    As you look into the engine bay at the front left, there is a belt that goes round the starter motor / some adjuster 'thingy' and I believe this is the culprit?
    On tick over the squeak comes and goes. If you give it a little rev the noise goes away. At the same time the adjuster 'thingy' seems to move and the belt does slip anymore.. (Tightens the belt perhaps?)
    What you reckon?
    May 2012
    20
    Sounds like the alternator belt. That belt won't run the starter motor, it runs the alternator and a/c normally. Try some WD40, if not expect a new fanbelt and possible tensioner.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Ah thats what i meant! the alternator - not the starter motor!...
    Il give it a squirt of WD40 then
    Strangely enough it didnt do it this morning? Its cooled off down here.
    It was squeaking whilst the weather was hot?!
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,381
    Don't be spraying WD40 on V-belts, it will just make them slip more. WD40 is a lubricant you know!
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Most belt noises these days aren't from being loose.
    They are from worn or perished belts.
    Check the belt, general rule of thumb is to be able to twist the belt 90 degrees on it's longest run.
    If its lose, and doesn't have an auto tensioner, tighten it.
    A squirt of lube will normally work for a while. But will dry out.
    There is proper belt sprays. Something like silicone spray or ptfe will last longer.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    cheers - a new belt is less than a tenner - should i just change it / is it difficult?
    dex140's Avatar
    Dec 2009
    190
    My ond man has just done his! Alldegedly its easy ....hardest part is gettting the arch liner off!
    The Engineer's Avatar
    Apr 2011
    Mid / Northwest
    336
    Mine did this for around a month, I left it and left it then it got worse.
    Ended up replacing the belt, tensioner and alternator as somehow the alternator pulley bearings perished resulting in it falling off.
    Get it looked at ASAP as you may save yourself money.
    Apr 2011
    Mid / Northwest
    336
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Ouch! thanks for the heads up!
    The Damned
    Apr 2007
    South Yorkshire
    344
    Quote Originally Posted by The Engineer View Post
    I did the same with exactly the same result.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    i did actually give a squirt of wd40 to the tensioner trying not to get the belt and so far so good...?
  1. Noisy/squeaky belt?
    By r3stu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th May 2010, 16:14
  2. seat belt problem
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th December 2003, 03:10
  3. S4 Timing Belt Prices
    By s4harv in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th November 2003, 15:13
  4. Timing Belt Question from a newcomer
    By RichbagggA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2003, 17:24
  5. 2.8 Timing Belt or timing Chain ????
    Last Post: 20th October 2003, 07:10
