Sky InsuranceBadger5
Results 1 to 18 of 18
    Jan 2012
    1,837
    How common are failing wheel bearings?
    I don't know if its me hearing things - but I can hear a slight drone coming from the OSF wheel at 70mph.
    There is something there though and its noticeable even over Chris Moyles on the radio
    All tyre pressures and depths are spot on.
    2009 - 37k miles on a 1.9 TDI BLS engine.
    Any ideas? Someone please reassure me that I'm only hearing things
    3DTDi's Avatar
    Jun 2011
    Bristol/Gloucestershire
    239
    i have had a rear wheel bearing go on mine, was 50k 57plate, seems quite common as i have heard a few similar stories
    A3 2.0TDi 170 S Line Brilliant Black
    Plans: FBMFSW, RNSE MkII, S3 Diffuser and Skirts, OEM Bi-Xenon
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    58 plate S3, 21k, NSF GOOSED! £255 to get it changed.
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Jan 2012
    1,837
    Mine is still very faint - will be listening very closely from now on - a long shot, but would this be covered under warranty - still under Audi warranty 'til December
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by a6_chris View Post
    Yes mate - wheel bearings should not go during warranty period. I have a 2006MY sportback and the bearings are fine.
    Jan 2012
    1,837
    Super, thanks Mike. Was getting worried incase I had to throw more £££ at the car
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    Luke's went on his 06 plate A3 with around 55k on the clock, so yes its not uncommon.
    Apr 2012
    N. Wales, LL22
    1,224
    what are you doing to your cars! :O
    passat 186k miles, all orignal bearings
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Jan 2012
    1,837
    I'm doing nothing to mine - gets an easy life on the motorway with no town driving!
    Although I do think it's cursed - problem after problem - Nigel will back me up on this
    _G_
    _G_'s Avatar
    Jul 2011
    869
    70k now all original bearings - even inspected them and they are good. motorways on weekends.. combined driving in week.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    had 2 go on the a3 at 50 1 on the s3 at 35 common as muck
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    I'm on 49k now, on an 08, mine are still ok, I hope
    Aug 2008
    Manchester
    130
    Out of curiosity what would happen if you just left it?
    Jan 2012
    1,837
    I would assume the bearing would either collapse = wheel comes off or the bearing would seize.
    But I'm no mechanic
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Very dangerous... if left unattended the wheel can start to flop around and damage your brakes etc. in the process. Worse case is driving on a motorway and the wheel comes off making you suddenly change lanes and that could be a recipe for disaster in traffic conditions. Just keep listening out for rubbing/grinding noise from the wheels every now and then - music off/quiet road and listen to any sounds that may give you concern. Otherwise its real easy to do a basic test.. you could always jack the car up/use axle stands to be safe.. place your hands on the wheel at the 9 o'clock poistion and 3 o'clock position, gently try rocking the wheel as if you were going to take it off.. if there is excess play in the wheel then this could be a sign of potential wheel bearing failure.
    Aug 2008
    Manchester
    130
    Quote Originally Posted by Super_G View Post
    I get a bit of noise around 50mph, goes after 60mph, the steering wheel is also slightly to the left when driving straight, it doesn't pull to the left though, any ideas? Jacked it up for the wobble test but they're solid, has been told previously it could be due to having two different manufacturer tyres on the front - previous owner was a moron. Probs gonna be going for a new tyre on the front so they match this week anyway but'd be good to know if it needs anything else.
    13
    My car has 39,000 miles, and I have had both my front wheel bearings replaced twice!
    Car is a 2010 Audi A3 2.0T Quattro.
    May 2012
    Rochdale Lancs
    34
    My A3 2.0 Tdi Quattro has one of the rear wheel bearings gone (and I foolishly replaced the diff thinking that's what it was..oops) so I'd guess quite common. My garage are testing the car to determine which corner has gone but I suspectI'll end up having both rear ones done as a precaution.
  1. How to change front wheel bearings
    By jemis in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 19th January 2012, 21:31
  2. how wide are you wheels and offset???
    By s3_kev in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2010, 05:39
  3. How much to replace wheel bearing??
    By Keefo in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2009, 19:07
  4. How much are my wheels worth ??
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th May 2007, 13:29
  5. How much are these wheel & tyres worth?
    By MiT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2007, 17:46
