EM TuningAH Fabrications
    Nov 2006
    Cheshire
    881
    Limp Mode due to DPF failure - how far can I travel?
    Guys, I have a PD170 VW Passat with the dreaded DPF issue. Yesterday morning on the way to work the DPF and EML lights came on the dash, then last night the Glow plug light came on and the car has been in limp mode ever since. I have the car booked in at Shark Performance tomorrow to have DPF delete and remap done, BUT, Its appx 70 miles from me to Shark in limp mode. Will it be ok to drive this distance while my car is in limp mode? Im worried about getting stranded!
    Audi A3 2.0TDI S-Line
    OEM+
    Coming soon: VW Passat 2.0TDI 170 DSG
    Aug 2008
    Manchester
    130
    I did it from Manchester to Stafford, around 50ish miles, you should be fine. The main problem is the lack of acceleration so just be careful, if you treat it softly it should pick up a little quicker than flooring it.
  1. HOW FAR ARE YOU TRAVELING TO GTI INTERNATIONAL
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2011, 14:36
  2. how far can i lower my a4 avant
    By mercer1589 in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st March 2010, 22:27
  3. Wheel refurbs, how far can they go?
    By DavidW in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2010, 18:16
  4. Service indicator on - how far can I go?
    By bikefright in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th March 2007, 22:14
  5. limp mode due to inlet manifold pressure HELP !!!
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2005, 19:39
