Monster MotorsportEM Tuning
Results 1 to 25 of 25
Like Tree1Likes
  • 1 Post By Rick @ Unicorn Motor Dev.
Thread: EGR Blanking plate 2.0 TDI. Any improvements?
    Mar 2012
    Somerset
    22
    Hello there!
    I recently removed and cleaned up my EGR as it was completely covered and also noticed the inlet manifold was pretty thick too. I decided to try a blanking plate for the EGR to see if it made it run any better.
    I bought it off of eBay for £2.99, took 2 minutes to fit...but i haven't really noticed any difference, it seemed to idle a little better but apart from that nothing. It also caused the engine management light to come on.
    Just wondering has anyone else tried it and actually found it has improved anything?
    Jack
    dex140's Avatar
    Dec 2009
    190
    I fitted one on sat! Seems to idle loads better, im currently monitoring mpg to see if there is any improovement which there is meant to be!
    Mar 2012
    Somerset
    22
    Yer I noticed the idle, and now you mention it, my mpg was running high 40's mid 50's most of the time. Has it made your engine management light come on? I have taken mine off again the engine management light has gone off. Might put it on again and leave it for a bit longer.
    May 2009
    West Yorkshire
    1,628
    The engine management light will stay on until you have the car remapped and have the EGR valve deleted out of the new map.
    If you continue to run your standard map then the EGR valve will always bring on the engine management light and you can't turn it off in VCDS as far as I'm aware, I've looked into it before.
    Audi A3 2.0L TDI S-Line Sportback
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    It runs smoother because the engine isn't getting dirty sooty air fed into it!
    If you do a blank, then it's good to decoke the inlet too, you will be suprised how dirty it is. The car needs remapping in order to switch off the management loght
    Rick
    tdi-man likes this.
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Mar 2012
    Somerset
    22
    Thanks for the help and advice!! Seem to be finding more problems with my car as the mileage increases, on 130k now!
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Seat do a 'reduced' size EGR gasket which is meant for the MK3 Seat Ibiza for about £5 which fits, try using one of those & it will restrict the EGR but not totally close it so the engine will run better but not show any warning lights on the dash
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Quote Originally Posted by max69vk View Post
    I take it you got it from Seat dealership?
    VCDS USER
    Apr 2012
    N. Wales, LL22
    1,224
    028 131 547 B from your local vag parts desk
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    max69vk's Avatar
    Apr 2012
    745
    It's a standard part I believe the code is : 028131547B , I havent fitted mine yet as the car has other issues to be dealt with first, but its a popular mod on the Seat forums & for around a fiver its worth a look. The only thing that may come up is with a diagnostic scan the car will show as having an EGR flow rate not being correct, however as we're the ones restricting the flow it's nothing to worry about, no lights should be popping up on the dash though.
    max69vk's Avatar
    Apr 2012
    745
    Quote Originally Posted by Ste_Nova View Post
    Beaten to the punch!
    May 2009
    West Yorkshire
    1,628
    What's the benefit of doing this?
    Will it make the 2.0L engine a tad more refined on idle or is it wishful thinking?
    max69vk's Avatar
    Apr 2012
    745
    Yep. it improves the idle massively.
    May 2009
    West Yorkshire
    1,628
    Lol are you being sarcastic or serious?
    dex140's Avatar
    Dec 2009
    190
    No defo imprrove the idle a great deal.... been running mine blanked for two weeks now!
    May 2009
    West Yorkshire
    1,628
    Think i'll have a punt at a fiver, do seat dealers stock them or are they ordered in?
    Jan 2012
    Stockport, Cheshire
    748
    It does improve the idle, yes.
    max69vk's Avatar
    Apr 2012
    745
    Should be a stock item, if they dont have it in it usually takes 24 hrs or overnight
    Apr 2012
    N. Wales, LL22
    1,224
    Quote Originally Posted by AidenUK View Post
    audi have them too
    VCDS in North Wales
    May 2009
    West Yorkshire
    1,628
    audi have them too
    You got a part number please?
    Apr 2012
    N. Wales, LL22
    1,224
    up there ^^^^ with the pic
    VCDS in North Wales
    May 2009
    West Yorkshire
    1,628
    Of course, whata knobhead lol.
    Mindak's Avatar
    Nov 2013
    Wiltshire
    243
    Old thread revival! Lol
    Anybody been running one of these reduced gaskets?
    A3 2.0 TDI S-Line
    Mindak's Avatar
    Nov 2013
    Wiltshire
    243
    Anybody?
    A3 2.0 TDI S-Line
    Jan 2014
    Norfolk
    68
    Quote Originally Posted by Mindak View Post
    Anybody?
    i too would like to know how the reduced plate performs ??
    Audi a3 s line 140 bhp 2007 red. Jabba Sport remap 180 bhp, red carbon fibre wrap ,interior trim ,team heko wind deflectors, xenon bulbs white / ice blue , red audi badge , completely debadged on the rear , led mods in all footwells red , 18" s line rims , red alloy gaters , black plasti dip front grill ,
  1. EGR blanking plate
    By dannyh in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2012, 23:33
  2. Allard 'Powerpipe' EGR delete kit Vs EGR blanking plates?
    By BudgieV8 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2011, 19:52
  3. EGR blanking plate size 2.5tdi
    By nanafagis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2011, 11:25
  4. Blanking egr on 2.5
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2011, 17:33
  5. Blanking plate for EGR valve. Does it work wonders
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th May 2004, 15:12
