EM TuningBadger5
Results 1 to 31 of 31
Like Tree5Likes
  • 3 Post By PH1L
  • 2 Post By PH1L
Thread: Guide: The definitive 2009- LED Facelift
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    Hi guys,
    Since this is becoming quite a nuisance and others are unable to use the search feature here is the lowdown on the 2009 LED Headlight facelift including electrics (from a 2004 8p chassis onwards to 2008), thanks to NHN and all the others who assisted along the way, This has been quite an expensive little conversion so if you find this info in any way useful feel free to buy us a beer
    Any questions keep them in the thread I don’t like repeating myself 1 million times, any clarifications etc I can answer via pm
    Firstly this conversion is a lot of money to complete the approximate total cost is £3000-£5000 if you are paying to have this completed properly and depending on the configuration that your car is currently in.
    If you are completing all of the work yourself and are purchasing used parts then you should be able to get it all done for just short of £2000.
    If you’re still up for it the nitty gritty starts here
    Parts Required:
    Facelift front panel (radiator surround)
    Facelift crash bar complete with mounts and polystyrene insert
    New headlight washers
    Facelift bumper and grill
    Facelift wings and fitting kits
    Facelift headlight brackets
    Facelift headlights ballasts and bulbs
    Under engine and front wing arch covers
    Central electrics unit – P/N 8P0 907 279 K
    Xenon Leveller unit - P/N 4L0 907 357
    Wing mirrors complete with indicators (my 10 dumbos or my11)
    Door modules: P/N 8P0 959 801 M (Drivers) / P/N 8P0 959 802 M (Passengers)
    Bonnet release cable
    The work – Note this guide is not a step by step process it only documents the required modifications in order to tweak your vehicle to the new parts
    First step is obviously to strip the front end of all body panels
    Next is to begin by fitting the front panel, depending on the stack of tolerances in your cars chassis you may need to reposition the captive nut underneath the skin of your inner wing of your chassis
    Once this is complete you should be able to bolt down the front panel, crash bar and re-house your radiator.
    The wings as we all know by now are a completely different fit in that they mount in 3 places as opposed to 4; the following detail is in my opinion the most OEM looking solution,
    Take the largest bracket from your fitting kit and rivet it to the centre mount on your wing, use this as a preset to adjust the remaining brackets to suit your chassis, once you have the wing sitting level and flush with your door I recommend that you drill and tap the centre bracket hole to suit its position, I then used some button head torx screws painted to my chassis colour to fill in the old bracket holes. Once both wings are fitted then you can complete assembling the front end as per ETKA / Elsawin
    Now for the fitting of the mirrors, Note that I wouldn’t recommend using mirrors from the wrong door version i.e. 3 door mirrors for a 3door car
    These will require your new door modules to be fitted and you to rewire your door card as per the wiring schematics in Elsawin, note if you have puddle lighting some of the earths will require joining this involves almost completely removing all the wire tape from the loom so its best to have some of it to hand.
    If anyone does want to add part numbers etc please post them as a replay and mods or myself will add them in.
    I will follow up with pictures detailing the fitting of the wings vs. the OEM.
    klik, ~RS~ and MrWhItEwOlF like this.
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    My codings of ce and xenon leveller
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000008169983
    Coding: F58E5F17A014100000000000000000000008EE175A06001E00 0000000000
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4L0 910 357 A HW: 4L0 907 357
    Component: AFS 1 H01 0030
    Revision: 00000001 Serial number:
    Coding: 0000028
    Shop #: WSC 06443 128 44669
    VCID: 2A5F45D185E436E
    Part No: 7L6 941 329 B
    Component: AFS-Modul links H03 0004
    Component: AFS-Modul rechtsH03 0004
    klik and ~RS~ like this.
    Mods
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    It should be noted that you will also need facelift bonnet hinges along with spacers to suit the wings approx 3-4mm thick if i recall
    Mods
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    Hi mate
    Now, I bought an S-line front bumper + S3 grill + both wings + front panel ( plastic thing ) + led headlightds .. We are cool till here
    do we HAVE TO buy that one; Facelift crash bar complete with mounts and polystyrene insert OR can we shape the crash bar by trimming a bit like we do when fitting the S3 bumper?
    According to your answer I'll buy the crush bar.. Anyone may help here?
    Second question; I have halogens right now, I'm going for leds, I got the led headlights; which adaptor should I use? Any direct link or picture or website? LEt me know the answers please
    Thanks!
    '' Wanna Trade Your Pre-facelift BRUSHED ALU interior trim with my Piano Black ones? '' PM me..
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    the design is different so i would reccommend the new crash bar, trimming of the polystyrene wouldnt be too bad to reuse the old but the relative cost is negligable
    for the headlights i would buy a plug from audi and repin and wire in the sensors, kill two birds with one stone effectively, be the cheapest way there is only 16 pins after all, if not that then the kufatec bixenon adapter will suffice
    Mods
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    In order to be a guide hopefully;
    Any part numbers of the part? Or how should I search it on ebay?
    And any wire scheme in order to adapt it :D ?
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    you can get the wiring diagrams from elsawin, the plugs id have to check in etka, there isnt a lot of change really you just pin in the level sinsors and repin the plug if i recall, luckily mine was there from factory
    Mods
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    yea, I wish I was lucky that much
    PArt numbers would be really great!
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    BTW; is it a S-LINE bumper?
    Audi A3 8P Frontstoßstange PDC Modell 2009 Facelift
    Teilenr: 8P0 807 437 H
    This is the same one that I bought but could not be if its an s-line or not :s
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    if you link in a pic or the advert i can check
    Mods
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    Thanks mate
    This is the same one:
    http://ipocars.com/imgs/a/a/z/w/d/au...2011_1_lgw.jpg
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    sline lad
    Mods
    Jul 2012
    Cambridgeshire/Huntingdon
    41
    Hi im new so might sound stupid but im in the process of repairing a car so thought id do this conversion as i had some parts available, with the 2010 halogen lights, do the need coding aswell? or just repining or use of a kufatech adapter.. and i thought it was 10 pin from 2003>08 to 14pin for 08>2012 cars.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    i cant recall as i only upgraded from adaptive bixenon to LED adaptive bixenon, they will need coding a central electrics unit and a xenon leveller unit at a minimum
    Mods
    Jul 2012
    41
    Cheers PH1L, i recieved headlights in the post today, £32 off ebay and thought i'd check how different the connections are, so i plugged them in and turned the switch and they worked , The car is a 2003 1.6 SE, the side lights dont work though, dunno if its a bulb or what?!
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    Should the LEDS re-coding?
    MY car is getting done in a few days and I'll need my deadlights at nights!
    If yes, could you please give me some deails or codes?
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    code as i have above, if you have the ce unit i listed put that in and goto one of the bytes that has headlight type in it and code it for led with bixenon
    Mods
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    alright mate, just a quick one... the headlight washers, i have checked etka and seen that they are listed as a different part number for the facelift model... how much difference is there and are they definitely needed to be changed if facelifting or can the original prefacelift ones be reused? i am just summing up the options of a facelift and if its worth it.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Joereynolds89's Avatar
    2010 Facelift!
    Dec 2010
    Leicester
    165
    I started the conversion about two years ago and have still never finished it due to time commitments... Therefore I'm considering having a friend split it as its easier then selling in its current work needed state
    Reason this has come about is because that I finally after a year of having a 8p0 907 279 k went to fit it today, to have my light sensor not work with the new module, still have indicator errors (though they work etc) and will probably take me another 6 months to get round to repinning the plugs!
    Therefore the K module is up for sale as of today once I work out what it's worth, as I fitted the A back onto the car... Door modules and full front end conversion etc will come after!
    Reason for this post is to those considering the conversion, either make sure you have the bits from the start, plenty of time available, money for those extra bits you didn't realise, and access to wiring schematics... Or be well off enough (and I'd probably say stupid enough) to pay a garage to do it all for you! Considering you could probably just sell your car and buy a facelift model for the price a garage would charge!
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    Quote Originally Posted by Joereynolds89 View Post
    I have also had this light sensor issue. It's due to not having the newish version. You'll have to change it to get it working again.
    Oct 2013
    hi im new to the forum , ive been asked to look at a Audi A3 2008 (58 plate)
    i ve had an audi a3 dropped off which has had most of the conversion done BUT
    the body controller is the earlier type (8P0 907 279 N) has what 10 smaller plugs the car is a 58 plate. All the information on here i can find is for the later body controller with the 3 big plugs
    i feel that i might have to a half way house , have drl's + side to ignition and put shutter motor to high beam and get the right switch for inside the car (owner has bought late switch and blew 2 up )
    if anybody has got any information i'd be most gratefull
    John
    foxymk1's Avatar
    Apr 2012
    doncaster
    271
    Is there a step by step guide to doing this ? I can't seem to access Phil's thread on vagoc
    Jun 2013
    22
    I have a 2009 facelift with DRL's but not the LED ones....Can I just replace them with the LED ones without coding etc? I'm also getting rather confused with the control modules, ballasts etc as the headlamps I have bought come without.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    Firstly the headlights you have won't fit straight in as you need a wiring adapter. the ones on your car have a 10pin plug on the back and the LED ones have a 14 pin plug... the adapter can be bought from Kufatec: Xenon/HID Headlights - Adapter- Audi A3 8P & 8PA Facelift-36752_M
    secondly you would need to code them in once fitted otherwise the car won't power them up correctly and will result in errors.
    Thirdly the module is the unit that connects up the headlights to the car, with the wrong (lowline) module you won't be able to upgrade to the LED DRL headlights but most 2009+ cars i have seen are capable of taking the LED DRL headlights.
    The ballasts are the power boxes that light up the new xenon bulb in the newer headlights which you will also need, without these the bulbs won't light up. The ones you have in the car would be halogen lights so don't have a need for ballasts.
    hope that answers your questions
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
    Jun 2013
    22
    Thanks Ash187, that does help a lot. Unfortunately, it seems too much for me to do!
    Any idea what the headlights are worth (as a pair or single) without the control module and ballast?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    Where abouts are you based?
    headlights without ballasts depend on condition... do they have bulbs?
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  28. #27
    Jun 2013
    22
    I'm based in Birmingham.
    No bulbs, condition of them is very good, no crack or broken brackets
  29. #28
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    I'd say around £400-500 as they are second hand and missing the bulbs and ballasts... best to put them on ebay
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  30. #29
    Jun 2013
    22
    Really? I would have expected a lot less!
    Do you fit them? If so, how much would you charge if I had all the bits?
  31. #30
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    il pm you
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  32. #31
    Jun 2014
    does anyone have a number for the fitting kit for the wings?
  1. Replies: 74
    Last Post: 17th April 2014, 00:16
  2. VCDS is there a definitive guide.( i need a bit of help)
    By RMH1A4cab in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th August 2011, 16:56
  3. 2009 Facelift Sportback led tail-lights: Poor indicators
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2011, 12:20
  4. 2009/2010 Diffuser - The DEFINITIVE answer.....
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th June 2011, 21:03
  5. Definitive list of the facelift changes...?
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2004, 13:49
