Monster MotorsportChris Nott
    Jul 2011
    Sheffield
    36
    Audi A3 2.0TDI - Error codes...
    Hi
    I have finally got the error codes off my car, luckily I haven't had to use it much recently so its just sat there.
    The two error codes I have are ( details as seen on here VAS 5051 Error Codes ):
    4C66 - P3102 Motor fur Saugrohrklappe-V157 kein Signal
    42B3 - Kühlerlüfteransteuerung 1 Kurzschluss nach Masse
    Now from googling I have found out the following
    4C66 = Engine Intake manifold-V157 is no signal wondering
    42B3 = radiator fan control a short circuit to ground, liquid cooling failure, fan spins up
    Obviously this is the handy work of some google translate, could anyone elaborate on whats wrong here? Im fairly confident in fixing broken parts on cars have changed timing belts/suspension and all sorts before, but when it comes to diagnosing the issue Im a little stuck so any help would be much appreciated
    27,105
    Intake manifold flap is probably faulty, remove it, take apart & check for broken plastic teeth inside as this is one issue, also could just be dead now aswell.
  1. Reading error codes on Audi 8P 2003
    By x1nick in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th April 2012, 18:41
  2. Error codes
    By amit91987 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2012, 12:08
  3. S4 Error codes?
    By Tavli in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2009, 10:41
  4. Error Codes
    By SDO in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2009, 12:18
  5. Error codes!
    By S4ZippyZoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2004, 12:43
