Badger5Volks Autos
    May 2012
    Derbyshire
    A3 convertible window fault
    Hi everybody I've got a 58 A3 convertable and the rear o/s window won't work so I can't put the roof down I've tested the motor and it works fine and I've even replaced the main window switch block and still no joy any ideas please thanks
    27,014
    How have you tested the motor?
    Did you detach the control module thats part of the motor?
  1. Electric window fault
    By HOUCH in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2011, 20:42
  2. TT Window fault
    By pablocurrants in forum TT/TT-S/TT-RS Forum
    Last Post: 17th February 2010, 16:41
  3. problem with drivers window on tt convertible
    By karen in forum TT/TT-S/TT-RS Forum
    Last Post: 18th February 2009, 23:17
  4. Up down window fault
    By SOULdOUT in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th August 2006, 16:31
  5. Electric window fault.
    By imported_highlander1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2005, 16:17
