Badger5AH Fabrications
Like Tree1Likes
  • 1 Post By PH1L
Thread: Plug & Play???
    May 2012
    Rochdale Lancs
    34
    Plug & Play???
    Asked this question on another thread but it got lost amongst my other ramblings so I thought I'd pop a new thread up. Has anyone here had a rear diff/haldex changed by a garage who didn't have Audi diagnostic equipment?
    My fear is that once the haldex control unit is disconnected from the old diff, then the closed circuit will be broken & once reconnected to the replacement diff (coming today) it may throw up all manner of fault codes & I'll have ABS lights & all sorts coming on & end up with a mutant car that runs 1WD from the rear offside :-/ I hope it doesn't need a setting up procedure & that it's a simple mechanical bolt on.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    i know of many poeple who have disconnected the controller for an upgrade without the need for a clearing of faultcodes, id imagine this to be the same, drivecycle should sort it, i can assume youre going to replace the haldex oil as per std procedure
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    May 2012
    Rochdale Lancs
    34
    I'll definitely put a new filter & oil in it. I replaced these a week ago in an attempt to fix a whirring from the diff but to no avail (it's still there if not worse) so I've bitten the bullet & the new diff arrives today.
    Hopefully it'll be ok then. Makes me long for the days of my old UR quattro with it's barn door engineering ;-p
    When you say drivecycle should sort it, what does that mean? Forgive my numptiness.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    with it up on the ramp fill the oil and change the filter leave the top plug loose run the car in neutral for 15 let everything settle check fluid, then nip up and run through first and 2nd still in hte air check fluid then go for a 10 minute drive out with the car stop shut off the ignition and start up again and drive all should be well
    know what you mean about the barnyard eng miss those days
    Nine Pack likes this.
    Mods
    May 2012
    Rochdale Lancs
    34
    Nice one. I've made a note of that. You're a gent :-)
  1. Is it Plug&Play for my car? MFSW
    By KemiksiZ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2012, 12:20
  2. Is dension gateway 100 plug and play with Concert III
    By heyes_s in forum In-Car Entertainment
    Last Post: 8th February 2011, 17:22
  3. Is dension just plug and play on Concert ii+ /3?
    By heyes_s in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2011, 13:56
  4. plug and play chips
    By Budgie21 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2010, 08:42
  5. Xenons are plug and play!
    By AkoyaMike in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2006, 11:01
