Yeah just double sided sticky foam stuff, took mine off as it was starting to peel off
just peel it off, and soak the left over glue with a paint & tar remover substance, the likes of terps or white spirite, even nail varnish remover will work and just work the old glue off with a cloth, DO NOT USE A SCOTCH BRIDE PAD!!
As I have a Black Edition I decided to swap mine for gloss black rings. I waited a while before I fitted the new black ones, to be sure having rings on the boot was the right thing to do. On all my previous cars I had debadged them as I liked the element of surprise / sleeper / "what IS that car pulling away from me" LOL
Be warned if you do take them off they are stuck on very VERY well. Also if you are replacing them with another set, apply a masking tape box around the originals to maintain the right position in which to stick your new ones to.
