Sky InsuranceVolks Autos
Results 1 to 14 of 14
Thread: Broken spring!
    mikeyboy's Avatar
    Aug 2011
    343
    Broken spring!
    Hi peeps, I went on a beer run lastnight & on my way home i could hear that awful clonking noise from the front suspension. When i got home i had a quick look & found that the front o/s spring was broken. I'm going to phone my local vag specialist tomorrow to book the car in. My question is should i just replace the broken spring or should i also change the n/s spring? I was also wondering should i be changing the shock absorbers along with the springs? I will be extremely thankful for any info. Cheers.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    For pretty much ever, its always been 'recommended' to replace shocks and or springs in pairs.
    Not once have i ever had a customer want to change them in pairs unless both were leaking etc.
    I also wouldnt change them in pairs on my own car.
    The shock should be fine, its probably only lost the last coil, so whilst noisey, its not like there is no spring left. Obviously if its leaking, it will need changing. But if its just happened, no reason it should damage it. Cars drive for months with broken springs before they get picked up on service / mot, and only have a spring changed.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    mikeyboy's Avatar
    Aug 2011
    343
    So if the shocks are not damaged i'm basicly looking at 2 springs?
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Id replace the broken one myself.
    I wouldnt change the other just because one broke. The spring will still be in place, just with a broken coil. The other one wont be ruined over this. If it hasnt cracked yet, no reason to think its faulty.
    They may try and convince you to change both, but as i said, never have i changed both on customers car just for the sake of it. Ive worked at main dealer 10 years or so.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    mikeyboy's Avatar
    Aug 2011
    343
    Cheers mate. I'll give you an update when i get it sorted.
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    Change both, chances are if ones snapped the other may be on its way out. I found it was cheaper to buy a full set of aftermarket springs from DPM.
    The handling and ride are now so much better!
    55' BMW 330Cd M Sport
    The ones that have been left behind:
    • 2004 VW Golf R32
    • 2004 Audi A3 2.0 TDi Sport
    • 2000 BMW 318i M Sport
    Private plate for sale: Y 7RYY
    mikeyboy's Avatar
    Aug 2011
    343
    Quote Originally Posted by Sheikh:1579960
    Yeah i probably will change both springs. Would be a pain in the arse having to book it in again a few months later to get the other side done. Another question i have is did your steering feel very light for a week or two while the springs were bedding in?
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    Hmm not really if i'm honest it was just a bit harsh for the first 100 or so miles. But now it's just amazing to drive! I've been chucking it round corners like mad and its properly smooth when you want it to be iswell.
    I went for the 30mm apex springs. A) Because they are the closest I could get to a stock sport set up B) because it was cheaper to buy a set of them then two sport springs.
    Good luck with whatever you do
    • 2004 VW Golf R32
    mikeyboy's Avatar
    Aug 2011
    343
    Quote Originally Posted by Sheikh:1579987
    Cheers mate.
    mikeyboy's Avatar
    Aug 2011
    343
    Got the car booked in for wedensday morning, was hoping to get it in today or tomorrow but the garage is snowed under with work at the moment. First come first serve as they say lol. On the plus side i'm going to get them to have a look at my parking sensors while it's with them, bloody things seem to work one day then dont work the next day. Anyway i'll give an update on wedensday to let you peeps know how i get on.:D
    The Engineer's Avatar
    Apr 2011
    Mid / Northwest
    329
    Quote Originally Posted by mikeyboy View Post
    Could you clearly see a broken spring when looking through your arch?
    I only ask so i can check mine, i get a clonking noise when going over small bumps at low speed
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    That could be your rear stone chip guard or something like that. Mine makes the same noise. If your springs are broken, the car should sit lower and the ride and handling will be horrible.
    • 2004 VW Golf R32
    mikeyboy's Avatar
    Aug 2011
    343
    Quote Originally Posted by The Engineer:1580480
    Yeah i can actually see the spring is broken as it has dropped below the strut on the shock absorber.
    mikeyboy's Avatar
    Aug 2011
    343
    Job done! The vag specialist that i've used a few times now changed both springs (genuine audi springs), which i think is common sense really, no much point just changing one and not the other. I'm booked in again on monday for my parking sensors. They did a scan & found one sensor was knackered but they cant get the paint to colour code it with my car until monday. So i'm really happy that my springs are sorted & my parking sensors will be sorted in a few days. I highly recommend this garage for anyone in the scottish highlands (Kennys autos Vw & Audi specialists) which is located in Seafield road, Inverness.:D
  1. S3 BROKEN REAR SPRING
    By speedy lynn in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2011, 20:13
  2. S3 BROKEN REAR SPRING
    Last Post: 17th February 2011, 12:47
  3. Broken spring - how much to repair?
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2010, 22:08
  4. Broken front spring
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2010, 16:02
  5. broken spring
    By bredhurststeve in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th April 2006, 16:47
