Monster MotorsportVolks Autos
Like Tree1Likes
  • 1 Post By Rom
Thread: Fuel Leak!!
    Apr 2011
    Somerset
    72
    Fuel Leak!!
    Hey all,
    Just looking around the car earlier and found what appears to be a fuel leak, seems to be coming from the item bottom left with all the pipelines coming of it. Is this the fuel filter? Looks like it may not of been tightened down properly as the fuel is all over the casing dripping down into the wheel well. Anyone had experience of this and am i heading in the right direction before i get the tools out?
    Thanks in advance
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Only just got mine, and not had it apart. But id say yes, thats the fuel filter. No other logical thing for it to be really.
    Is it leaking from a pipe, or the top of the unit?
    Wont hurt to check the bolts are done up, pipes are on properly. Will also be some sort of seal on the lid, which may be perished or not fitted properly.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    Apr 2011
    Somerset
    72
    Looks like from the top of the unit, the pipelines are bone dry so I'm guessing as you say it may be the seal. The top screws tightened only very slightly so will have to keep an eye on it, i presume its not pressurised when the engine is off so should be safe to remove?
    Dec 2011
    York
    93
    Has the filter just been replaced?
    Possible Symptoms;
    * Rubber seal incorrectly seated/missing
    * Securing bolts not tight
    Please contact Administrators about advertising.
    Apr 2011
    Somerset
    72
    January i had a full service carried out but only just noticed the fuel leak so I'm thinking the seal may not of been replaced
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Theres normally a safe way to de pressurise a system, like removing fuel pump fuse and letting engine die etc on petrols.
    I never bother, but i work on cars all day. It wont be high pressure till after the main pump anyway. Tank pump is only for supplying to the diesel pump.
    Never mess with the common rail systems though. They can reach ridiculous pressures. Toyotas generally run 30k psi plus.
    ollie86rn likes this.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
  1. Fuel leak
    By dublinS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st January 2011, 20:18
  2. Help!!! Fuel leak!
    By sebbelcher in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th March 2010, 23:58
  3. Fuel leak!!
    By Crash in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2009, 23:01
  4. S4 Fuel Leak
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th February 2009, 17:51
  5. Serious help please - got a fuel leak
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2008, 13:25
