EM TuningBadger5
Results 1 to 7 of 7
    Aug 2008
    Manchester
    130
    Removing bumper - help!
    So i've spent the last hour undoing all of the torx screws etc but it's refusing to budge, seems reluctant close to the headlights on both sides, anything i've missed or any tips?
    Been following this Fourtitude.com - DIY: front bumper removal and blackout grille install (think i've just answered my own Q by looking at number 10, Ipad wasn't clear at all) but i'm not sure on part 7, where is that torx screw exactly? The one marked as D?
    Aug 2008
    Manchester
    130
    Right, i'm stuck on the lil plastic bits shown below (A&B), how do you remove them/which tool? So close!
    Aug 2008
    408
    Remove the arrowed bolt, did you remove screws underneath the bumper as well
    Cal
    Aug 2008
    Manchester
    130
    Quote Originally Posted by bluequattro View Post
    Cal
    If you mean the bolt the arrow's pointing too that's already off, it's the rubber things labelled a and b I'm struggling with, can't see how they come away. All screws taken out underneath, it's only sticking next to the lights so am pretty sure it's just those rubbery things.
    Pipsqueak's Avatar
    Jan 2012
    Glasgow
    117
    theres a photo further on in your link that shows you a direction to pull the bumper in. i haven't ever taken one off so don't know if thats right or not
    Mar 2011
    109
    The two screws inside there are torx aswell.
    from memory you get at them from the side, I used a torx allen key which was easier to get at them.
    Have you taken the wheel lining off completely? or just bending it back with your hand?
    Wanted: A lottery win so i can afford all the mods i want!
    Aug 2008
    Manchester
    130
    Quote Originally Posted by Orts View Post
    Just bent it back on both sides and undid any screws I saw underneath plus the bolt. So are the 2 rubbery screws torx? Having another go in a min.
  1. Removing front grille without removing bumper?
    By maars in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2008, 11:14
  2. removing S3 front bumper
    By SnoopS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2008, 22:29
  3. Help removing bumper
    By Layerz in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2007, 18:55
  4. Removing front bumper
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2006, 23:44
  5. removing rear bumper
    By imported_happy123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th February 2006, 15:51
