JMB RetrofitsEM Tuning
Results 1 to 16 of 16
Like Tree2Likes
  • 1 Post By z1mma
  • 1 Post By z1mma
Thread: bought [ brough74 ] S3 but got few Q's now :/
    z1mma's Avatar
    Apr 2012
    Birmingham
    101
    Wink bought [ brough74 ] S3 but got few Q's now :/
    Hiii
    finally after looking around got ME a S3 thanks to Audi sport!
    here’s the run down on specs,
    AUDI S3 2.0T FSI QUATTRO 2008 with 19000 Miles
    In stunning Metallic Phantom Black with black leather interior
    Manual 6spd gearbox
    GSM mobile phone prep
    Multi-function flat bottom steering wheel
    Xenon headlights
    Heated front and back seats
    Satellite navigation plus
    IPOD connection built in and Aux in
    Rear parking system
    Cruise control
    Climate control
    Bose sound system
    Space saver wheel
    Sunroof
    Privacy Glass
    Electric/heated door mirrors
    Auto lights and wipers
    Auto dimming mirrors
    Isofix
    Full Audi service History #on long service#
    Lowered 25mm on H&R springs
    10mm spacers on the front and 12mm on the rear
    Cupra R front splitter, easy to remove if not to your taste
    RS6 Front grill
    Darker rear lights #genuine Audi#
    Genuine Audi mats
    Later spec alloys with Michelin pilot sport tyres 5mm front, 6mm rear
    that’s the exterior and interior done... I don’t know if its slandered on all s3's or not but all the inside are like the black edition models, black interior, dials, mirrors sunroof buttons etc...
    Milltek exhaust with black tips, Not the loud one
    Induction kit
    Upgraded fuel pump with new cam follower
    Uprated sach clutch
    RS4 Fuel pressure regulator
    Later spec “D” Recirculating valve
    Revo stage 2+ Software
    Approx. 360 BHP and 360lbft
    with all those mods its pulling 360bhp BUT it feels like it’s not :s
    a friend of mine has stock 58 plate s3 and raced from 3rd gear and he kept up with me all the way on a few occasions started to even edge forward... his is a facelift model and about 30k on the clock and a manual, I think his a member on these forums too.. ( yooo! lol )
    so maybe a bad map? any advice?
    also, at low revs when the car drives in 2nd gear without gas/clutch, the car makes like this knocking noise from the engine as if something is loose, is this normal? a few people as well as stealers believe it is, can someone confirm?
    lastly, breaks squeaking... I had these checked and pads have a lot of life left... but when just pressing the peddle firmly the brakes squeak.. what could this be??
    your thoughts much appreciated
    z1mma
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,552
    Hi z1mma lovely spec car as i,ve seen and been in it, map was fine pulling right through the gears , best to scan car using vagcom , or if your near sheffield get it down to statllers get it check out , they also have a rr and if there is a problem with map it will be covered under some sort of warrenty ..
    Nov 2004
    Tonbridge, Kent
    912
    I suspect the Revo map could have been set back to standard or turned down. Find someone with an sps and get it turned back up. No way could a standard car keep with a stage 2+.
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,552
    z1mma i have a sps switch as i remember the car could be set up to default settings from the tuners ..
    Feb 2009
    Aberdeen
    2,621
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Brakes squeaking isn't wear, it just needs a dab of grease behind the pad (inside edge to the caliper).
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,552
    Hi there make sure your running 97 ron or higher as i only use vpower petrol , maybe try some injector cleaner , and also best to get the car checked out by someone like statllers an audi specialist ..
    Kelvin_S's Avatar
    Apr 2012
    Bristol
    237
    Well I guess 80bhp isn't really that much more, It can easily be canceled out by Bad shifting, weight difference or turbo on it's last knees.
    To do:
    MY11/ S3 Chrome mirrors /Springs / 20" Alloys / Wrap
    Dream plate: B055 KKS One day.
    brough74's Avatar
    Oct 2010
    423
    I always used 97 ron and its been fine and its had injector cleaner fluid when the map was done. apart from that as you felt on the test drive it pulled well. As for the knocking noise you mention i dont know unless its just the clutch grabbing as you have no throttle on.
    S3 gone but not forgotten, now on a Golf R
    z1mma's Avatar
    Apr 2012
    Birmingham
    101
    had to use normal petrol due to accident on motorway and fuel gage showing 10 miles in stop/start traffic lol... so maybe due to this then? but it makes that much of a diffrence?? the guy i raced was using normal petrol too.. i need to find a rolling road in birmingham and take it from there
    the knocking its not like as if its about to cut out or anything, more like a thuding lol, and only happens further slowing down during snail pase..
    apart from beeing a lil paraniod, im in love again :D the car is a beast, and very very happy with the investment!! :D
    Feb 2009
    Aberdeen
    2,621
    Using 95RON would show less power on a standard S3, the effect will be multiplied significantly on a modified car. Get some V-Power in there and see if your friend can keep up.
    Hunt is over
    z1mma's Avatar
    Apr 2012
    Birmingham
    101
    pics
    MartayMcFly likes this.
    Feb 2009
    Aberdeen
    2,621
    Christ I want that grille!
    Hunt is over
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,552
    Thats what i thought you have put in normal petrol this with pull the timming back , like martin said get some vpower straight away ,and get a sps switch as well ...stunning car, welldone ...
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,484
    I'd of removed the spliter, makes the car look a bit odd with lowered suspension. Fuel is crucial when it comes to tune a car:
    Facts about high octane petrol - YouTube
    However 80bhp difference can be due to engine device fault, split intake pipe, overboosting turbo, exhaust sensor failure etc. so best is to get it checked via VCDS and put on a RR.
    On top of that if it was me I would rather bought it standard and do all the bits myslef with garage that I trust and could do all the checks before and after just for peace of mind and tuning fun factor:].
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    z1mma's Avatar
    Apr 2012
    Birmingham
    101
    tuning fun factor will come into play when i get bored with stage 2+ and move on to 3
    Kelza likes this.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    did you maybe disconnect the battery? or maybe car went into a limp mode?
    you should plug in vcds and see the boost values.
    does it use more fuel than usual and do you get burbles noises from the exhaust when you leave the throttle in 2nd gear?
    if so i got the last issue too, car is going on monday to a garage to see what's wrong.
    and once i felt lack of power then i used vcds and saw that boost is 1.2 bar which is i think stock did a throttle body adjustment and it vent back to full boost.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
  1. Just bought my A3
    By dannyh in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2010, 07:32
  2. Bought an S3 :)
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2008, 12:58
  3. I've bought......
    By smitch in forum General Chat
    Last Post: 5th April 2007, 16:51
  4. Look what I've just bought...
    By golf in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2007, 14:54
  5. I've just bought...
    By neversaydie in forum General Chat
    Last Post: 17th February 2007, 18:43
