Chris NottAH Fabrications
Results 1 to 23 of 23
Thread: Fly wheel
    May 2012
    85
    Fly wheel
    I'm getting mine changed to a single flywheel from the dual 1 is this common my top garage recommended it any suggestions
    May 2012
    85
    Dec 2011
    York
    93
    Awesome post
    May 2012
    85
    Lol just wondering what Audi car owners think of this choice
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    I don't know what car you have,but a SMF will leave a fair bit of added thrash and harshness,as it's job is to damp all of that out.
    If you gave a bit more information,like why your garage has recommended this,is this engine modified etc etc it would be helpful,as you're going to have to change the clutch as well if you do this,and unless you're looking at an engine with a lot of power(we didn't do mine until we'd got beyond 440bhp),you really aren't going to get much from this.
    May 2012
    85
    Audi A3 54 plate 85k 2.0 TDI
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Quote Originally Posted by Smithy121 View Post
    Still a bit short on detail,but if it isn't extensively modified for greater power,I cannot see why your "top garage" is recommending a move to something that will require a new clutch as well as the flywheel,in return for more noise,thrash,vibration and so on,and no real benefit.
    If the clutch and flywheel on yours need replacement,then you could argue it on those grounds,but I would still be inclined to keep the DMF and maybe add a Sachs organic clutch for durability,but not an SMF.....I have a Spec clutch and SMF on my S3,and you can easily feel and hear the extra engine thrash.
    H88
    H88's Avatar
    Apr 2012
    Lewisham/London
    232
    I am on the way of needing to replace my clutch as well,dont known if I should go for original audi clutch or after market part?I have 2.0 tdi 2004 and non-modified car.Any suggestions?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Quote Originally Posted by H88 View Post
    I'd get the appropriate Sachs organic and DMF if possible,as it's reliable,tough(good for around 400lbs)and retains much of the stock clutch feel.
    May 2012
    85
    My Audi is standard
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    My Audi is standard
    Thank you...got there in the end.....my advice stands,don't get an SMF unless you're prepared for the downsides.
    May 2012
    85
    What are the downsides
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    I guess you may not have read my previous reply....
    Quote Originally Posted by S3Alex View Post
    Still a bit short on detail,but if it isn't extensively modified for greater power,I cannot see why your "top garage" is recommending a move to something that will require a new clutch as well as the flywheel,in return for more noise,thrash,vibration and so on,and no real benefit.If the clutch and flywheel on yours need replacement,then you could argue it on those grounds,but I would still be inclined to keep the DMF and maybe add a Sachs organic clutch for durability,but not an SMF.....I have a Spec clutch and SMF on my S3,and you can easily feel and hear the extra engine thrash.
    So.....just in case,I'll say it again,...noise,vibration and harshness will ALL be increased,and you WILL notice that,as even on my car which is already pretty loud at times,you can both hear and feel this.
    I don't mind too much,but bear in mind yours is a diesel and you are going to get more of this.
    Dec 2011
    York
    93
    To finish from above;
    If you want to go out in your overalls with your straw cap ploughing fields then buy an SMF because your car will sound like a tractor
    Please contact Administrators about advertising.
    flying oyster's Avatar
    flying oyster
    Jul 2009
    wimbledon
    545
    jrd your talking ******** mine sounds like a combine harvester !
    S3 8L ming blue westys old car shed loads of mods
    Dec 2011
    York
    93
    Is that supposed to be more refined? haha
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Quote Originally Posted by - Jrd - View Post
    Nice one.....I've tried to explain this,but it's difficult.
    Mine is petrol fed,so it's not as bad,but over semi-race engine mounts,and all the other bits,you can still tell it's got an SMF fitted,but you can't tell someone who isn't listening.
    Dec 2011
    York
    93
    SMF's are much more road useable on petrols, With harsh engine mounts that will increase the cabin vibrations but SMF on diesels is just a massive no. Unless the dual mass is incapable of keeping the transmission link you wouldn't change it.
    Think thats that wrapped up
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Let's see!
    flying oyster
    Jul 2009
    wimbledon
    545
    i have the silenced smf on my tdi i run more pwer than standard and plan to go further soon. on a recent sprint day my comrades couldnt beleave on tick over how quiet mine was and on a thrash i cant hear mine either but the non res miltek may have something to do with that but a smf suits my car for the kind of driving i do
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Unless any car is heavily modified and producing a lot more torque then standard stick with a DMF on both petrol and diesel cars. SMF sound bad on petrol cars and bloody terrible on diesel cars.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Dec 2011
    York
    93
    While on this subject, do you know what torque DMF is rated to?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Good question.....all I can say on that is mine managed 440lbs without blowing up.
  1. Fly wheel or not too flywheel???
    By djcatfood in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2011, 22:49
  2. Possible Fly Wheel Issue ?
    By ashurz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2010, 10:53
  3. Fly wheel?
    By A3ster in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2009, 11:35
  4. S3 Fly Wheel Problem
    By AuldReekie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2009, 08:49
