JMB RetrofitsAH Fabrications
Results 1 to 11 of 11
    Dec 2008
    16
    Fitting LED DRL.....
    Hi,
    I picked up my 58 plate Sline A3 Sportback a couple of weeks ago and it came with the bog standard DRL. I have seen some of the slightly newer A3's with the LED DRL which run along the top edge of the head lights, would it be relatively simple to swap these over if I could find a set?
    I am not too fussed about them being Xenons, if this makes any difference?
    I have had a look through the posts and can only see gash links to non OEM LED lights on fleabay
    Tom
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    post a pic of what lights you have i suspect you are prefacelift
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Quote Originally Posted by P5SND View Post
    Can't be prefacelift as they didn't have DRL unless fitted with Xenons.
    If it is facelift (and it should be on a 58 but it is right on the change) then it is a straight swap to Xenons with LED drl in terms of actual fitment. You then have to fit washers, levellers etc...
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    Quote Originally Posted by audicruiser View Post
    he never stated if he had xenons or not, granted he said bog std but it could be a late register prefacelift
    but you cant get the led drls like mine without xenons
    Mods
    Feb 2012
    Southampton
    74
    Am I right in thinking you only need auto levelling for bi xenons, but not for xenons?
    Dec 2008
    16
    sorry it is a face lift without Xenons, do the LED only come on the xenons then?
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    Yep you will need a set of headlights ballasts adapter loom new leveller unit and level sensors
    Mods
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Gweev View Post
    No you're not ! Sorry mate
    Feb 2012
    Southampton
    74
    Oh!
    So, not much point in retrofitting a set off fleabay then. Explains why Audi charge nearly a grand for the option too.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    well its worth it though
    Mods
    Rob2k68's Avatar
    Feb 2012
    109
    Maybe a white LED bulb upgrade is an option granted not as impressive as the xenon headlamp unit ?
  1. Help: Fitting DRL LED strip to A4 B7 S Line
    By m4trix77 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th September 2011, 06:27
  2. My DRL LED Replacement, (not the LED strip)
    By PetrolAholic in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th October 2010, 03:00
  3. LED DRL Retro Fitting??
    By A3 Sport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2009, 20:55
  4. LED DRL
    By 06060918@Brookes.ac.uk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th June 2008, 07:05
