Badger5Monster Motorsport
Results 1 to 7 of 7
Thread: S3 Cam Follower
    pinterovski's Avatar
    Oct 2010
    661
    Add pinterovski on Facebook
    S3 Cam Follower
    Hi!
    Is there any place that i can buy cam follower for my S3 online?
    Need to get this thing sorted,forgot about it when i replace internals for autotech
    Many thanks!
    Black roof,Tinted windows,Solar Orange Calipers,KW V3 Coilovers,
    HEKO Wind Deflectors,CAI ITG Maxogen,Non Res Supersprint Exhaust CB with custom Fi76mm DP,
    RevD with GFB DV+,Autotech HPFP,Custom SKN map Stage2,Forge ShortShifter,THS mounts,
    Twintercooler,Clutch is now on LOBA/SACHS!!!
    18 OZ Ultraleggera!
    365HP and 500NM of torque!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,322
    Have you tried stoke audi, there site sponsors. There at bottom of main forum page
    brough74's Avatar
    Oct 2010
    423
    I bought an uprated one that was twice as thick as the original, it took a while to come though. I think i bought it from FR Tuning
    S3 gone but not forgotten, now on a Golf R
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,087
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    Oct 2010
    661
    Sandra,Brough74 and Paullie BIG THANKS
    18 OZ Ultraleggera!
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    There is this one.
    http://=http://fr-rtuning-shop.co.uk...roduct_id=1770
    Product Information
    kmd-03023 KMD Upgraded 2.0TFSI Armoloy Coated Cam Follower
    After months of R&D KMD Tuning is pleased to present another product to our 2.0T FSI line up. Typically customers don’t pay mind to their cam follower and as you all know, the factory cam follower can cause fuel cuts when worn down. Additionally, from our experience and testing, when using an after market fuel pump the cam follower can wear down even quicker then normal.
    With that in mind KMD designed a follower made from the factory material, hardened to the same spec, and is .028 larger then factory. We also eliminated the factory c-clip (one less thing to fail). The reason we decided to use this specific increase was because after trying larger and smaller sizes this was the most efficient without causing cam wear. At 10k the follower thickness was at .019 and at 20K it was at the factory size, which now gives you an extra 20K and most importantly, piece of mind! This testing was done over a period of 8 months on 4 different vehicles that varied from stock to stg3 500hp cars. When running a stock car the wear on the follower was even less then stg1 vehicle.
    brough74's Avatar
    Oct 2010
    423
    Thats the uprated one i bought.
  1. Changing HPFP / cam follower on S3 8P
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2 Weeks Ago, 11:28
  2. 2.0T cam follower replacement and look how bad this is!!
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th October 2011, 20:11
  3. KMD Uprated Cam Follower - Stage 2+
    By Kelza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2011, 15:16
  4. Cam follower inspection per Audidriver recommendation-2.0T
    By master mariner in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th March 2009, 10:49
  5. 2.0 TFSI HPFP Cam Lobe and Cam Follower
    By KRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2008, 05:46
