Sky InsuranceChris Nott
Results 1 to 8 of 8
    Mar 2012
    91
    bkd misfire and long start issues.
    hi all, right my a4 has a bkd engine fitted. it did have BLB but i assume it got nuked like most of them do.
    I thought id post about the bkd in the a3 section as its not in the a4s. by code anyway.
    i have cold start issues, it will wind and wind and then splutter into life and run for 15 seconds fine. then will misfire and chuck white smoke out as in plumes, but if you take it for a drive it clears and only pops the odd puff.
    it drives fine under load with no major issues but if you try to drive constant it lurches, not bad bad but bad enough to make any passengers think you cant drive.............
    when warm it starts fine, still smokes and misfires.
    its had a head so its not the coolant issue
    its had a head loom
    its had all 4 injectors recon'd
    egr valve cleaned
    maf cleaned
    tandem pump gasket - someone had used the old gasket when doing the head and had also used that gasket sealer which had gone into the diesel and oil ways but iv sorted all of that now.
    oil change
    turbo seems fine, no play in shaft etc
    now what? injector readouts when warm where 0.71 0.31 1.32 -2.38. i then had them recond and they are fine!
    im sending the ecu off to be checked tomorrow.
    but could i be right in thinking that if the tandem pump gasket was the issue and the oil has mixed with the diesel and the car now has less than a quarter tank in that the fuel could be contaminated? just a thought?
    any help will be very much appreciated.
    Feb 2012
    Birmingham
    130
    I had the contaminated fuel from tandem pump in my a3. Didnt have what you are describing though, i had a judder when in 5th/6th between 1200-2k revs. This only happened when it was warm too, when it was cold you wouldn't know there was an issue.
    foxymk1's Avatar
    Apr 2012
    doncaster
    187
    hav you had it on VAGCOM? could be glow plugs
    foxy
    Mar 2012
    91
    nothing shows, glow plugs wouldnt cause smoke or an issue once its running
    foxymk1's Avatar
    Apr 2012
    doncaster
    187
    it would cause blue smoke from unburt fuel on start up and cause starting delay
    Mar 2012
    91
    i will get them done when i get the ecu back, as i guess there not to expensive
    Mar 2012
    91
    rang the ecu people today and they have said its the wrong ecu for the car, but how? when u search for bkd and blb ecus they are the same part number? but somehow they are different?
    will no if they check it this week sometime.
    Mar 2012
    91
    ahhhhhhh just spotted, the last 2 letters are different. i have 03g 906 016 gn?
  1. 2.0T FSI rough start up and misfire for first 2 seconds ???
    By ahed in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th June 2012, 20:54
  2. 2.0 TDI Misfire on start up.
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th January 2012, 14:09
  3. Boost issues TDi 140 BKD
    By n25gabe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2011, 12:35
  4. Long time to start - hunting with misfire
    By salad.dodger in forum General Technical / How To
    Last Post: 18th June 2011, 12:45
  5. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
