Chris NottVolks Autos
Results 1 to 18 of 18
    May 2012
    Essex
    32
    THE MOST ANNOYING RATTLE IN THE WORLD
    SO, There is a rattle coming from my front left wheel. it sounds like a heat sheild rattle but i've tried everything.
    Taken off the belly plates, tried to tighten the heat shield bolts etc...
    if you kick the wheel really hard it rattle a bit. but it rattles with every single bump you go over.
    Taking it to the garage in the morning, but i don't understand what else it could be.
    Sheikh's Avatar
    Aug 2011
    Surrey
    658
    Broken spring?
    55' BMW 330Cd M Sport
    The ones that have been left behind:
    • 2004 VW Golf R32
    • 2004 Audi A3 2.0 TDi Sport
    • 2000 BMW 318i M Sport
    Private plate for sale: Y 7RYY
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Is your car lowered?
    May 2012
    Essex
    32
    i've tried to rattle the spring and there is no play.
    To describe the sound. if i was to get a metal tray and really loosely bolt it to the front bottom left so when it went over a bump it rattled that would be the sold.
    May 2012
    Essex
    32
    no the car is not lowered. its the Quattro S Line, i did hit a pot hole a while ago too which i think brung on the noise
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    drop link
    but i did have a very bad noise
    shes banned from the car now
    May 2012
    Essex
    32
    Bez101 That made me chuckle! i've spent 4 hours trying to work out this rattle. the thing is i've taken the wheel off and hit everywhere with a rubber mallet and it won't make the noise. but if i put the wheel on and kick it it does... nothing is loose on the set up.
    May 2012
    Essex
    32
    and there was no play in the drop link at all
    bez101's Avatar
    Jul 2008
    7,947
    on my daughters a3
    2 garages said ni play in the drop links
    ended up replaceing and noise gone
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,387
    i've got the noise too, and a bit of feel throught steering wheel, and looked at it and never found anything, i'm also thinking that it could be the droplink as my car is lower than stock but i got used to it :D
    i will change it when it's time..
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    302
    Splash guards behind the take discs? They are flimsy metal that rot away. Bare in mind noise can travel so check all under the car and is even e tempted to drop the undergrad round and take it for a spin. Could be anything really.
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    302
    Take = brake.
    May 2012
    Essex
    32
    its not the splash guard either i honestly tapped/shoke/hit everything nothing made any noise... might just get a new drop link and try.. is it called something else as i can't find it on ECP
    bez101's Avatar
    Jul 2008
    7,947
    May 2012
    Essex
    32
    i've emailed the guy to see if they fit my car if they do i'm going to inspect them how would i tell if they where faulty???
    May 2012
    Essex
    32
    Right, the Guys in top Gear in St Ablans reckon its a Top Mount... So will be getting that sorted as its the first and only rattle... very annoying
    May 2012
    Essex
    32
    so it wasn't the top mount... garage inspected it and they couldn't find a problem... so i took the wheel off myself. Checked everything again, found the breakpad was wobbling.
    So i took it off, and found the clip had come a bit loose, so i viced it, got a centre punch and hammer and hit it until the clip was firmly in place.
    the back on she went and no more rattle.....
    Iceash's Avatar
    Mar 2012
    Brightlingsea
    390
    Why do brake pads do this! mine did that also, stupid bloody things...
  1. Annoying rattle!
    By clockwork.satan in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th February 2012, 05:47
  2. Truly annoying rattle
    By landopanda in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2009, 16:46
  3. S6 2000 Annoying Rattle
    By claytow in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th April 2008, 08:57
  4. VERY annoying rattle
    By imported_gek in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2005, 21:43
  5. Annoying Rattle
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2003, 22:15
