    May 2012
    P.R.N.D.S flashing
    I will be really gratefull if some one can help me, im driving audi a3 tdi 05 plate numb, this two weeks todrive but the car can not drive more then 30 mph and if you try to revers car can not be reversed, on dashbord the sign P.R.D.S. is flashing
    what can i do as i dnt know much about the cares
    for threedays if uturntheengine off andtry again the flashing with go but in 10 minute the same problem again
    thank you
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Post your question in the 8P section - your car is an 8P not 8L.
    I don't think it's a problem that will go away by leaving the car off for 3 days or 3 years unfortunately.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    BENJAMIN's Avatar
    Mar 2011
    471
    Common problem. Mechatronic unit failure. Go see Audi, it 'may' be under warranty if you have full dealer service history.
    Aug 2010
    1,540
    used to get this on older audi a4s/a6s. they had a transmission "range" sensor on the side of the gearbox that used to go faulty.
    dont think these have that tho. but it'll be along those lines...... the gearbox ecu doesnt know/cant tell what gear its in, thats why the p/r/d/s is flashing??
    id get it fault code read etc. if its a known fault then complain to audi for a contribution??
    can a mod move this thread to the 8p section for you?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,429
    Quote Originally Posted by murran View Post
    Thread moved to 8P.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    needs a scan at best will be a sensor or corroded plug
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
  1. IRREGULAR FLASHING
    By HOUCH in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2011, 11:37
  2. Indicators not flashing as they should
    By Izzy1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th November 2010, 14:41
  3. Immobilizer flashing
    By keny in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2010, 18:10
  4. Hazards flashing
    By Kitchy in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2009, 21:16
  5. Lights Flashing
    By ak_quattro454 in forum In-Car Entertainment
    Last Post: 21st November 2006, 18:08
