Badger5Chris Nott
Page 2 of 2 FirstFirst 12
Results 41 to 54 of 54
Thread: Audi a3 help
  1. #41
    May 2012
    85
    Quote Originally Posted by Graham89 View Post
    Sounds like a slave cylinder fault. Mine was leaking and I had the same symptoms. New slave cylinder, clutch, dual mass flywheel, master cylinder and £1000 later I had my car back on the road.
    Well hope it's not that serious
  3. #42
    Mar 2011
    Cleveland
    962
    Nope, I think you'll just need the slave cylinder - but get it bled first!!!!
    You have the new clutch already....
  4. #43
    May 2012
    85
    Quote Originally Posted by fangio View Post
    Phew how much are they and the diesel flap thing where is cheap place for that please
  5. #44
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    could be The wiper motor or corrdoded wires
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
  6. #45
    May 2012
    85
    Quote Originally Posted by P5SND View Post
    Thanks again just a query when i click the link what am I looking for the Audi part or does others fit/work
  7. #46
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    i didnt add the link, get a used one from ebay
    Mods
  8. #47
    May 2012
    85
    Audi Rear Wiper Motor with Rear Wash WipePart Number: 8L0 955 711 A - 8L0955711 A - 8L0955711A
    This is a genuine Audi Rear Wiper Motor, It was taken from a 2001 Audi A3 1.8T with the 4 pin plug
    Please check that this item will fit your carBEFORE bidding
    All parts may fit other cars/engines, check with your local dealer!
    Any questions please askPlease see our other auctions
    Will this work
  9. #48
    Mar 2011
    Cleveland
    962
    Doubt it, it's from an 8l and yours is an 8p. Someone will correct me if I'm wrong!
  10. #49
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    yourer right it will not fit
    Mods
  11. #50
    May 2012
    85
    Hi went to garage today been told its a problem with the hydrolic of the clutch bearing ??
  12. #51
    May 2012
    85
    Any 1 had this before help
  13. #52
    May 2012
    85
    Any body had this issue please help
  14. #53
    May 2012
    20
    The bearing is a concentric slave cylinder design.. Is there any irregular noises? Try putting your foot down on the top inch or so of the pedal? Any irregular noises then? Any change in pitch when the clutch pedal is depressed fully etc?
    Entirely possible it needed a clutch and dual mass flywheel but they've whacked a clutch in and decided to sell it as is.
    Master cylinder is a fairly easy job, some people remove the pedal box etc but it's not always necessary - slave cylinder if required is normally inside the gearbox bellhousing, going over the input shaft. The gearbox would need to be removed to replace this part.
  15. #54
    May 2012
    85
    No noises
