Chris NottMonster Motorsport
Results 1 to 9 of 9
    Mar 2011
    109
    Black Indicators (pic heavy)
    Since the sun was out again today I thought I'd throw the black indicators in. I bought them from - www.bm-town.com for just over £20.
    Here is the before
    They are a bit fiddly to get to, you need to jack the car up, remove the wheel and then remove the lining in the wheel arch. You will need a Torx 25 allen key or screwdriver for this.
    wheel off and lining removed -
    When this is off, you might find a couple of inches of mud behind it. this is what i found -
    this is what it should look like -
    You now have access to get to the inside of the panel, on the drivers side there is a metal box in the way -
    you can just the light popping through on this angle -
    The indicator case as a clip on one side, you need to press this in as you push it out, if you need to get something on the outside to slide underneath it just to ease it out, once the clip pops its out, then you simply pull the lead out and push into your new one and slot back into place, pushing the side without the clip in first and then popping the other side in, you will hear it lock once that clip gets into place.
    End product -
    Wanted: A lottery win so i can afford all the mods i want!
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    They do look much better but I have never had to remove the wheel arch lining.
    They usually just slide out no bother. Just push it against the spring side and they pop out?
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Mar 2011
    109
    Tried that first, was really really tight and didnt want to put a screwdriver in to try and get it out! No way I could get to the inside without going under that lining. Not confident enough to go in with brute force and see what happens! haha
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    slide and pull brother
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Mar 2011
    109
    Quote Originally Posted by P5SND View Post
    that would remove all the fun of taking the lining out! are you crazy?!
    Ash B's Avatar
    Jul 2008
    Cardiff
    5,808
    looks good mate
    Dark Vader Half sibling - MyThread
    May 2012
    31
    Looks nice mate, adds to a meaner/moody look
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    thats must have took ages for a 5 min job
    Dec 2011
    237
    Looks loads better mate
  1. My B7 all cleaned up.... pic heavy!!
    By outsideline in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th April 2012, 20:37
  2. what do you think??PIC HEAVY!!
    By tangerinedream in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2011, 19:00
  3. looking for ideas *** pic heavy***
    By dann1701 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th May 2011, 23:13
  4. S3 Photoshoot (Pic Heavy)
    By S38P in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2010, 08:46
  5. My A3 progress, pic heavy
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2010, 11:16
