EM TuningAH Fabrications
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 119
Like Tree11Likes
Thread: TPMS - A3 2012 - Coding Issues? VCDS users please check!
  1. #41
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,425
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Big test is to let your tyres down after the values have been learned. See if it flags up or not.
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi A3 For Sale: 2011 Audi A3 1.8TFSI Black Edition. Low Mileage. Great Condition. Manuf Warranty
    http://www.audi-sport.net/vb/sale-wanted-audi-cars/219560-sale-2011-audi-a3-1-8tfsi-black-edition-low-mileage-great-condition-manuf-warranty.html
  3. #42
    Veneeringman's Avatar
    Bazinga
    Aug 2010
    Back in the UK
    638
    Quote Originally Posted by Cruiser89 View Post
    Have already done this before I coded the bit 2 and it lights the tyre symbol on the dash after about 5 miles so I knew it worked, could never get the tyre pressures to store until I long coded bit 2 today.
    I'm going to test tomorrow to see if when I let some air out, I can reset via the DIS, will keep you informed.
  4. #43
    Jun 2010
    14
    It's only for MY12 cars. (Cars fabricated from up to july 2011, more or less)
    Because they don't have the possibility in the dashboard to have tpms buttom.There is no hole for that.
  5. #44
    Nov 2012
    35
    I have tried this on my 2009/07 A3 and gives me the error shown above :'(
    Sorry by the off topic but can anyone get to me the VCDS labels of the module 8P0 919 475 K (it's the module to parking sensors and i'm trying to enable the OPS + rear view camera without success)
  6. #45
    adz195's Avatar
    Sep 2012
    So just to confirm you enable bit 1 & 2 in byte 16. Do you still do bit 2 in byte 17? I've done it all and get no error in dis and it stores but in vcds i get fault code in can gateway in 4c tire pressure. Even though I have touched the can gateway and 4c is unticked. My car is a my11 a3.
  7. #46
    Nov 2012
    35
    Quote Originally Posted by adz195 View Post
    You only have to check if it are really working. Do you test the hold hill? Because if you have no errors in dis it means that you have both working. The 4c tire pressure it's the other system of TPMS that works with that menu's on the dis, probably it's normal...
  8. #47
    Nov 2012
    35
    Quote Originally Posted by vsantos69 View Post
    Can´t anyone help me?
  9. #48
    adz195's Avatar
    Sep 2012
    i think it is working it is storing via dis. Yet when I scan the car with vcds it flags up with fault in can gateway (4c). But I have not ticked it so why would there be a fault with it?
  10. #49
    Bazinga
    Aug 2010
    Back in the UK
    638
    UPDATE
    Hi All, so today i finally let some air out of one tyre, drove less than a mile and got the amber tyre light coming on and a larger red tyre symbol in the DIS, also in the DIS a warning came up telling me which tyre had lost pressure, great it works spot on!!
    Went to the garage inflated tyre to the correct pressure then went into DIS to reset the TPMS and it worked all the lights went out as it stored the values, so success and when it needs reseting i can do it in the DIS!!! see pictures above.
  11. #50
    PaulRS3's Avatar
    UK
    1,006
    Hi, a bit late to the party, but i managed to enable mine today.
    MY11 S3.
    I followed the procedure listed in this thread. ( Having already enabled HHA , I was confident this would work, with my ABS module.)
    Enabling the bit 1 & 2 in byte 16 and bit 2 in byte 17 are vital. ( and easily missed)
    I tried it WITHOUT 4C gateway enabled and got the following fault...
    Address 19 Can-Gateway 01044 - Control Module Incorrectly Coded
    and further down the list
    Address 4C Tyre Pressure II - just says cannot be reached ( does not show as a fault)
    it appears to want to be coded for 4C, even though it wont actually reach it.
    So, I ticked 4C, all errors will clear, all you will be left with is the "Address 4C cannot be reached" which shows in a VCDS scan, but does not show as a fault.
    03-ABS Brakes -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    Address 4C: Tire Pressure II
    Cannot be reached
    I have taken it for a 65 mile drive mixture of A/B and Motorway speeds, rescanned and have no faults. When i get chance i will test by letting a tyre down alittle.
    Audi RS3
  12. #51
    adz195's Avatar
    Sep 2012
    Quote Originally Posted by PaulS3 View Post
    MY11 S3.
    Cannot be reached
    Ok cheers mate will give it a go. Is strange why it wants 4c ticked though. Seems like there must be some thing missing from the coding.
  13. #52
    27,096
    It maybe like the 2009 facelift module in module 09, which shows 46 as OK on a gateway installation check, but 46 doesn't exist anymore, as its a combo of 46/09 in 09 only, so its a virtual module as such, which maybe what's it acts like for the newer dis based tpms for 4C.
    adz195 likes this.
  14. #53
    Jul 2012
    Cheshire/N Staffs
    1,308
    ABS module
    There isn't a tick box for Bit 1 in Byte 16 ?
    How do I enable Bit 1 without a tick box? If I change it manually in the yellow 1100111 box (reading from R to L) it doesn't accept the coding
    edit: Ignore me, I forgot to click on the appropriate hex field, after modifying the binary field :/
    edit2: It doesn't appear to work for a 60reg 2011MY 379AT ABS module car
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
  15. #54
    PaulRS3's Avatar
    UK
    1,006
    I enabled it manually in the long coding helper binary box. As you mention working right to left.
    Bit7,6,5,4,3,2,1,0
    changed bit 1 from a 0 to a 1.
    I then toggled checkbox for Bit 2 on/off/on to see it take affect.
    The two digit section of the long code (for me) changed from 39, to 3D ( bit 2 enabled) to 3F ( Bit 1 & 2 enabled.)
    close the long code helper and click "do it"
    My Binary code changed from before 00111001 (39) to 00111111 (3F)
    Audi RS3
  16. #55
    Jul 2012
    Cheshire/N Staffs
    1,308
    Thanks Paul
    So to confirm, did you have to modify 3 controllers? ABS, CAN gateway AND Instruments? Or just 2?
  17. #56
    PaulRS3's Avatar
    UK
    1,006
    Yes all three modules had changes made to them.
    Audi RS3
  18. #57
    Jul 2012
    Cheshire/N Staffs
    1,308
    Update: Success
    TPMS via DIS works on a 60reg MY2011 S3 with a 379AT ABS/ESP module.
    And yes, 4C is a virtual module !
  19. #58
    27,096
    Veeeight, can you PM me a full log/autoscan of your car please, its for research purposes.
    Also a pic of inside of your service book as it then shows me the gearbox/engine code so I can check wiring schematics aswell.
    TIA.
  20. #59
    27,096
    Big thanks to Veeeight for providing some logs/data for me, much appreciated
    veeeight likes this.
  21. #60
    PaulRS3's Avatar
    UK
    1,006
    Quote Originally Posted by veeeight View Post
    Update: Success
    To Confirm..
    TPMS via DIS works on a 60reg MY2011 S3 with a 379BE ABS/ESP module.
    HHA also works with this module.
    NHN likes this.
    Audi RS3
  22. #61
    Bazinga
    Aug 2010
    Back in the UK
    638
    To Confirm..
    A nice little bonus isn't it ? To be able to add this yourself with a bit of research.
    2012 Misano Red RS3 / Bucket seats Heated front & Rear / Aluminium Styling Pack / Bose / RNS-E / Bluetooth / Mobile phone prep low / AMI / Reversing Sensors / LED number plate lights / Led interior light pack / VCDS / Cruise Control / Exclusive Inlays / Auto Lights & Wipers / 8.5J fronts / extended leather / Michelin Pilot super sport tyres / and a few other things
  23. #62
    27,096
    Veeeight does your abs controller support HHA?
  24. #63
    Jul 2012
    Cheshire/N Staffs
    1,308
    I think it does, but not sure, didn't try as I wasn't interested in HHA on my car.
    Next time I get VCDS out I'll try it.
    I heard too many horror stories during development of HHA and EPB!!
    NHN likes this.
  25. #64
    27,096
    You can always disable it again, appreciate the effort
  26. #65
    PaulRS3's Avatar
    UK
    1,006
    Quote Originally Posted by Veneeringman View Post
    Certainly is. Took almost a year to the day from when i first posted my other TPMS thread, to get a working soloution. It wouldn't have been possible without the information from ASN. There were bits of information around the net, but this thread pulled them all together.
    Audi RS3
  27. #66
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Has anyone managed to get this to work on a 2010 yet?
    I followed the steps above to the letter, but get nothing at all on the DIS or a warning light.
    I get stuck at the same stage as others have mentioned in adaptation channel 37, where the pop-up box says the 4 digit code I need, but the box will only accept a 2 digit one.
    I've had to resort back to the method Silky had whereby you have to reset it using VCDS, but I'd obviously prefer it to be done via the DIS.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
  28. #67
    27,096
    What's your current abs module 03 coding, as I'm researching this for older cars right this minute with a newer abs module rewired in for testing purposes.
  29. #68
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Hi Nigel.
    I'm not sure what part you need so here's a load of numbers for you to crunch:
    VCDS Version: Release 11.11.6 (x64)
    Data version: 20121223
    Saturday,15,June,2013,18:09:43:35939
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 61 62 72
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 1342401209260003C80D02EC901D00923D0800
    Shop #: WSC 06314 000 00000
    VCID: 7AFE6668F5533AC86EF
    No fault code found.
    The only thing I've changed was to turn on Hold Hold Assist.
    The original coding before I changed it was:
    1342401209260003C80D02EC901D0092380800
    Hope that helps.
    NHN likes this.
  30. #69
    27,096
    You mean it only shows 2 digits & the assumption that it will only accept 2, I also thought this ages ago mate, so don't worry, just put the extra 1 in at front end & see what it does
  31. #70
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    I tried putting in the extra numbers (making the code something like 1101) but it didn't bring up the save button. It was greyed out unless I had 1 or 2 numbers in the box.
    So are you saying that I should be able to get it to work on my car?
  32. #71
    27,096
    I'm saying try it with 3 digits, is yours currently 01, if so try 101.
  33. #72
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Grrrrr, still no luck.
    Hi Nigel, I need your wisdom again.
    This is what I've tried:
    17 - instruments
    - entered security code 13861
    - changed first 4 digits of coding from 0004 to 0020 (adding 16)
    At this stage the error message comes up on the DIS about TPMS system malfunction.
    - adaptation channel 37 'read'.
    My original number is '1', I tried the up and down buttons, but no luck so I typed 101 in manually. Then pressed 'test'. It just changes the number to '11'. As soon as I try to type more than 2 digits in this box the button to save greys out.
    I've tried it on '1' and '11' as these are the only options I seem to have.
    3 - ABS
    - Byte 16, bit 2 checked. bit 1 is added manually so the code goes from something like 1111101 to 1111111
    - Byte 17, bit 2 checked
    At this point the TPMS error message on the DIS disappears, along with all signs on TPMS.
    CAN Gateway
    installed gateway 4C box checked.
    When I shut it all down and restart it, the little tyre symbol I used to have on the speedo to tell me that Silkys manual-reset version of TPMS was installed no longer appears and there is no mention anywhere of having TPMS. I go through all the menu's on the DIS, but there's nothing that has to do with TPMS.
    I think it's to do with the adaptation 37 that won't accept anything more than 2 digit's. See step 3 of the first post in this thread.
    I also noticed there was a bit to check in the CE module for TPMS, so I tried this checked on and off, but it didn't do anything.
    Help me Nigel Wan Kenobi, you're my only hope. I'm probably making a stupid error somewhere, but I don't know where.
    Incidentally, I enable HHA, so I would've thought I could get TPMS enabled.
  34. #73
    Jul 2012
    Cheshire/N Staffs
    1,308
    On your build codes sticker in the boot (or the service book) does it say 1AS or 1AT ?
  35. #74
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    I've just had a look and it says 1AT. Hope that's good.
  36. #75
    Jul 2012
    Cheshire/N Staffs
    1,308
    1AT is good. 1AS is no good.
    so your ABS controller supports TPMS.
    the problem seems to be your instruments. Maybe your age of car needs the physical push button in centre console to reset TPMS?
  37. #76
    Sep 2012
    22
    Hi I have enabled TPMS and the reset via the DIS I have the 1AT ABS controller that is supposed to be able to support TPMS but I cannot code the module even via long coding helper on a 61 plate RS3 is anyone able to help with coding for the brake electronics please?
    Attachment 30126
    Attachment 30127
    Attachment 30128
    Attachment 30129
    Attachment 30130
  38. #77
    SJ
    Jan 2013
    75
    Time to dig this one up again I'm afraid! Had my tpms warning light illuminate today having changed my pressures a little (good start it works!) Anyway this meant resetting it all via vcds as I haven't retrofitted the button, system reset using vcds and all is well again.
    Anyway this got me thinking, since I've retrofitted dis into my car maybe I can do away with the whole button idea and reset via the dis. Now I've read this thread for the coding and now have the option for the reset showing on the dis. Problem is when I try to reset it via the dis it won't store the values, I've checked against vcds and its not triggering the reset procedure at all.
    My initial thinking is perhaps an issue with the can gateway, as I can reset using vcds which is essentially what the dash would be replicating, is it possible that the gateway is just not allowing this communication through? My current can gateway part number is 1K0 907 530 AF, Any thoughts most welcome
  39. #78
    Muzza80's Avatar
    Oct 2013
    Glasgow
    553
    Have you ticked the relevant TPMS box in the 4c can gateway? I'm sure I read that this has to be ticked for it to work?
    2010 Audi S3 Sportback Black Edition TFSI Quattro
  40. #79
    SJ
    Jan 2013
    75
    Yeah 4c is checked, status reported as OK. ABS byte 16, bits 1 & 2 and byte 17 bit 2 all checked, instrument coding '+16' and channel 37 adaptations done.
    No errors are reported, the menu appears on the dis when stationary but just will not perform the reset
  41. #80
    Nov 2012
    35
    Quote Originally Posted by SJ View Post
    Hello,
    Your problem is on the DIS software. The one's that enables successfully the TPMS are those built in to the 2011 cars (Delivered since july of 2010, i suppose).
    Sorry for bad news. I do had the same problem, therefore i retrofited the TPMS button.
    By the way, the 4c module are no need, thats for the other system of TPMS.
    Regars.
  1. coding wiper motor with VCDS
    By andrewyzfr6 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2012, 16:58
  2. new steering wheel. VCDS Coding?
    By viceroy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd October 2011, 20:18
  3. VCDS coding for tails
    By tcardio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2010, 17:45
  4. TPMS check for me please
    By NHN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2009, 16:52
