Badger5Chris Nott
Results 1 to 33 of 33
Like Tree1Likes
  • 1 Post By SCFC_Messiah
Thread: Help! 56 TDI 170 - White Smoke and Loss of Power
    Mar 2012
    278
    Hi guys
    I was stopped in traffic today and noticed a large amount of white smoke coming from the exhaust of my car - revving seemed to make it worse. Then just a few minutes later it felt as though the car had lost power - it didn't have the same pull in 2nd as I'm used too. Over the next few miles of town driving it seemed intermittent - sometimes there was smoke, sometimes there wasn't. Sometimes it felt as powerful as ever, sometimes it didn't. It also felt like the revs were limited and that the idle wasn't as smooth as normal (though I may have been imagining that). There was no warning lights and no sign of mayo in the oil
    Anyway, I decided I needed to get the car home as soon as possible, but home was 15 miles away. Over the journey home (motorway) the car definitely didn't feel as though it had the same power as usual. At this point I was fearing that the turbo was on it's way out, when literally a mile from home the Particle Filter Warning Light flashed on
    Is it normal for loss of power and white smoke when the DPF is blocked? Or is there something more serious afoot?
    Please guys, any help or advice would be really appreciated. Thank you
    Apr 2012
    NL
    77
    no other warning/engine lights?
    If the turbo couldn't keep up as supposed to, I'd say the engine control unit would pick up on that, so lights would pop up. White smoke often is a sign of water consumption (whereas oil would give blue smoke), so I'd think more along the lines of a blown gasket (cilinder head) but I don't want to scare you. I hope someone else comes along and has better news (and more knowledge haha)
    Mar 2012
    278
    Nope, no other warning lights
    It wasn't a massive amount of white smoke, just more than what I would say was normal. It's not permanent either
    Dannykn9 likes this.
    Dec 2011
    York
    93
    Your DPF will be blocking up and trying to regenerate - Hence your intermittent problem.
    If your doing short journeys/slow speeds all time your DPF soot load % will increase to a point where the warning light is emitted and then the ECU will take control(Active regeneration) in an attempt to lower soot load by making adjustments to fuel injection, if continuinely ignored it will lead to complete DPF failure.
    You need to take it on a 20-40minute drive(depends on speed) to raise exhaust gas temp(EGT), Try to do 40mph-70mph and don't use 6th. Need to be higher in rev range(Passive regeneration). Go tonight while theres no traffic.....
    If this fails you'll be forced to take it to dealer for a Regeneration Cycle on VAS5051, as said if that is none responsive you'll be looking new DPF.
    Ive stated everything so you understand, Whichever end of the scale your at.
    If you do alot of small journeys as said, you may want to consider DPF delete as these are not suitable for that type of driving, They need to be regularly on motorway/higher speeds/Raised EGT.
    Report back
    Mar 2012
    278
    Just taken it on a long run as recommended by the owners manual. Must've done about 40 miles averaging 60MPH in 5th.... But the DPF light is still on
    No lack of power issues since the light came on and as far as I know, no smoke either
    Going to take it to an Audi specialist tomorrow. If the DPF needs replacing, how much am I looking at?
    Dec 2011
    York
    93
    Were you sat at low RPMs on your journey?
    And if DPF is required; Audi A3 2.0 tdi 170 DPF CAT 08 | eBay
    Mar 2012
    278
    Thanks JRD, a very detailed post. I ensured it was above 2K RPM as that's what the manual suggested
    I also noticed something strange. After accelerating hard I came to a set of traffic lights. Whilst stopped, it sounded like the engine was idling high. I looked down at the dials and the needle was indicating 1K RPM. I tapped the accelerator peddle and it dropped back down to 800 RPM where I believe it should be..... Something else to worry about? Or is it nothing? (I'm just a bit paranoid all of a sudden lol)
    Mar 2012
    278
    JRD, two questions for you if you don't mind
    1. As regards to the 'Regeneration Cycle' - does that need to go to an Audi dealer, or will an Audi specialist be able to do it providing they have the correct diagnostic machines?
    2. I'm very interested in having a remap and DPF delete. However, the car is on 98K miles and I'm afraid the extra stress and strains of increased power may cause components to start failing sooner, considering they've already been through a lot of miles (turbo for example). Is this a legitimate concern, or should I just get on with it?
    Dec 2011
    York
    93
    Firstly as to your idle high/extended drop time that will be due to blockage again as theres too much back pressure in exhaust.
    Regeneration cycle - I only know of the genuine VAS units to be able to do the cycle but im sure there may well be snap on gear that may be capable but you'd just have to check with your chosen specialist if they're equipped to complete job.
    The only difference with dealer doing it is theres a programmed cycle on the VAS machine that monitors EGT temps/injector cycle whilst driving and prompts you to drive in a certain gear/rpm for a period of time. Basically just keeps it in an optimal state to ensure regeneration. I've completed many
    DPF delete - In general a remap increases the torque rating output putting extra stress on flywheel/clutch friction, And boost pressure on turbo spool. But you could remap a car and drive it double the mileage than a standard one - All depends on driving style. If your playing traffic light racing(im sure you dont..). If you understand what i mean? Remapping is nothing to worry about, Aslong as done by a competent company then you can see smoother engine running and boost pattern and usually higher MPG's. You can even have a remap thats purely based towards MPG increase - i.e minimal performance gains only purpose is fuel consumption.
    If you want a remap and you can't get this DPF regenerated/ or price is uneconomical then i'd say just crack on and do it.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Dec 2011
    York
    93
    Quote Originally Posted by mjr901 View Post
    Thats different pal, DPF is on the front pipe/downpipe.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    my bad! In another world tonight for some reason.
    this might be the answer...
    DPF-Delete Hi Flow Downpipe - JBS
    Mar 2012
    278
    Jrd, excellent advice again. Thanks mate I'm warming to the idea of a remap and DPF delete now, especially as I do mainly city driving and I don't want this reoccurring
    But just to be 100% sure, you think the intermittent smoke and power loss may have been related to the impending DPF problem, even though they occurred a good 10 miles before the DPF warning light came on? I really hope so.
    Dec 2011
    York
    93
    The Particulate filter warning light is only emitted once soot load has exceeded around 45% which then goes from Passive regeneration to Active. Thats why its emits a warning light to alert you that you need to "get ya foot down" :P
    Mar 2012
    278
    Long Life in Swansea want £799 just to delete the DPF, with a further £150 for the Stage 1 remap (Top Gear Tuning map).... Seems expensive to me. They reckon it's a big job because it's bolted onto the turbo
    On the other hand there's a tuning company 20 miles away who quoted £499 + VAT for the DPF Delete AND Stage 1 'DNA' remap. They can also do a REVO remap but it'll cost a little more
    Does that seem a good price lads? And should I pay a little more and go for a REVO map, or will DNA suffice?
    Dec 2011
    York
    93
    Forget longlife for mapping... The DPF delete is easy to exchange, downpipe removal is simple on them, 1 allen key bolt on V-Band connection to turbo then unclamp at centre, 17mm stabilising bracket mounted to gearbox. 10-15min job and its off.
    Whereabouts are you from? may be able to point you in right direction for mapping
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Did you get anywhere with the DPF light? I've found that the handbook way of things never works so I take the car for a good 20 mile motorway run at a steady 70mph (**cough**) and leave the car in 4th at all times, running the car at 2k rpm (according to the manual) doesnt get the DPF system anywhere near hot enough to burn the crap off.
    Dec 2011
    York
    93
    And theres nothing wrong with attempting to do it a few times, only going to lose some fuel. No labour. Higher EGT's the better...
    Mar 2012
    278
    Quote Originally Posted by - Jrd - View Post
    Swansea, South Wales
    The company that quoted the DNA or REVO remap are 'Got Boost' in Bridgend. From what I've read on local car forums, they have a decent reputation locally and have rolling roads to test the map properly etc
    Quote Originally Posted by max69vk View Post
    I took it on a 40 mile run, but to be honest I stuck at 60ish in 5th. Car was only just above 2K RPM.... Maybe I didn't boot it hard enough then?
    Thanks lads
    Mar 2012
    278
    Ok mate, I'll have to take it on another run. Would 3K rpm for a prolonged period of time be too high?
    A garage locally have offered to put in on their Bosch machine to start the Active Re-gen. They said they wont charge me if it doesn't work which I thought was tidy of them. So it's a toss up whether I go to them first or straight for a DPF delete and remap now. Hmm....
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Gotboost is very good. Clean workshop, full of expensive cars like nobles and full racing cars and drift cars.
    There was a meths Leon in there too. looked the bizz with BBS's on.
    I had my TBE milltek fitted there. The mechanic knows exactly what's what on these machines.
    Had a nice Alsatian too, I got the dog a bit irate as I gave it some abuse. all good fun
    max69vk's Avatar
    Apr 2012
    745
    An active regen just dumps more fuel into the the cylinder after compression to increase the exhaust temperature which then burns the muck out of the DPF, its why your car RPM raised to 1k rpm instead of the usual 800, & why it was running lumpy at idle. If it didn't cleat it then, it wont now. Take the car for a good booting & keep it at around 3-3.5k rpm, it should get the light out
    Mar 2012
    278
    Sorry, I meant they'll put it on the machine and do the 'Regeneration Cycle' that JRD suggested in his first post
    I'll definitely take the car out later. It feels counter intuitive booting a car when the warning light is on But now I know it wont cause any damage I'll thrash it
    Thanks Max. And cheers MJR, it's good to hear positive reviews
    Dec 2011
    York
    93
    The active regen is only an advanced state to lower the soot load, if your still driving it like "a pensioner" then it still won't do anything.
    See how it goes later just keep it 2500rpm-4500rpm
    Mar 2012
    278
    Took the car on a 30 mile run. Kept the speed around 70MPH with the car in 4th so it was revving around the 3.5K mark.... Still getting the warning light unfortunately
    Noticed white smoke on two occasions again. Took the opportunity to visit Got Boost - the guy was a little concerned about the intermittent smoke so was kind enough to put the car on VAGCOM for me. No engine fault codes were thrown up. Not my smartest move but when I got home I stuck my head down by the exhaust with the car running to take a closer look - although no smoke, the fumes were strong enough to burn my eyes. Is that normal? Or is it a sign that the car is over fuelling? Burning coolant maybe?
    I'm resigned to removing the DPF now and actually looking forward to having it mapped at the same time.... but I'm still really quite concerned about the intermittent white smoke. I just hope it's related, but I've read no other reports of white smoke problems with DPF failure so I'm not confident
    Jul 2010
    Merthyr Tydfil, United Kingdom
    881
    Did they monitor the pressure sensors of the DPF to look for variations? Did they try an active regen??
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
  28. #27
    Mar 2012
    278
    Na, he just quickly checked for engine fault codes - presumably to see if there was something showing up that could be causing the white smoke!?
  29. #28
    Jun 2007
    Yorkshire
    307
    FYI, My DPF has only been on twice in 10k miles, and that was when I'd just acquired three points which calmed down my driving style. Now I'm back to booting it, no DPF for me, and I'm not doing much in the way of long distances - it's mainly city driving. Oddly, the relaxation in driving style doesn't seem to have effected my economy very much either (45-55mpg average).
    When it did come on, 60-80mph in fourth did it down the motorway, DPF light was off in a matter of minutes.
    Ibis white 2010 A3 2.0TDI Black Edn.
  30. #29
    Jul 2010
    881
    Quote Originally Posted by SCFC_Messiah View Post
    Hmm strange then as normally if the DPF isn't regenerating its due to a faulty sensor which should show up as a fault code........
    I know a chap where his DPF light came on; too it to VW, they couldn't force a regen and advised him to have it replaced. He had a delete pipe put in and the guy who removed it said you could eat your dinner off the inside of the DPF.....
    My Posh Golf
  31. #30
    Mar 2012
    278
    I thought that myself after leaving. If there's a problem with the DPF why didn't it throw up a fault code!?
    *sigh*
  32. #31
    Mar 2012
    278
    Bad news.... I'm looking at a £2K+ repair bill
    The seals have blown on the turbo, so oil has been sucked into the system and through the inter cooler etc. Presumably the oil has been sucked into the DPF filter causing it to clog, which is why it threw up the DPF Warning light
    Quoted £930 for the turbo - thought that was expensive but called around and it seems about right
    £580 for the DPF delete and Stage 1 remap
    8 hours labour
    New oil and filters
    New inlet pipes to the turbo
    The system needs flushing out, which means removing the bumper etc to get to the inter cooler
    Add it all up and it tips the scale at around £2K.... I just pray its not caused any damage that we've not anticipated, because it's already costing more than I can really afford
    Afraid to say I wish I never bought the car now. Only owned it 3 months, I know it's the risk you take, I just hoped that buying a newish car (compared to previous cars) I'd be avoiding the repair bills for a while. Turns out its given me the most expensive bill to date.... by some way
    Gutted.
  33. #32
    max69vk's Avatar
    Apr 2012
    745
    You can get an exchange re-con turbo for around £450 + the DPF should be more like £1200 at most!
  34. #33
    Mar 2012
    278
    Do you have more details on that mate? Like what companies do it etc
  1. A3 TDI 170 - White Smoke
    By codfather14 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2013, 21:57
  2. Replies: 3
    Last Post: 6th September 2011, 14:47
  3. Replies: 5
    Last Post: 11th August 2011, 20:50
  4. 170 TDi Quattro power loss and economy
    By Mini-mad-matt in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th October 2010, 21:15
  5. Loss of power after first service (2.0 TDI 170 DPF)
    By Fleagle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2009, 07:41
