Monster MotorsportChris Nott
Results 1 to 10 of 10
    Apr 2012
    12
    Audi S3 8p Misfire cilinder nr 3
    Hello guys
    My brother owns an Audi S3 8p Year 2008.
    The car is stock and have only 12000 miles on them is like new.
    He has a problem when looging with vag com the car don´t show any problems. But when we go to Engine and click on the map 15 " detecting misfires" the cilinder nr 3 is always counting them at low rpm 720 / 760. The car runs great annd everything looks normal.
    We have already purchased new spark plugs, changed the coil packs and the problem persists on the cilinder nr3.
    Anyone knows how to resolve this problem ??
    Best regards
    Paul
    Apr 2012
    12
    Yesterday we tried to change the egr for a new one but the problem remains....
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Tried swapping the plug lead from cylinder 3 for one from another cylinder & seeing if the misfire moves to the other cylinder you've moved the lead to?
    Dec 2011
    York
    93
    Quote Originally Posted by max69vk View Post
    How can you move the plug lead, it doesn't have any? Uses coilpacks and he's replaced all 4....(should of moved coilpack around to save buying them) but thats done now.
    Is the car physically misfiring then? Not just the statistics shown on Datalog?
    max69vk's Avatar
    Apr 2012
    745
    Good point I meant coil pack! You sure its not an injector fault?
    Apr 2012
    12
    On the engine faults the car don´t show nothing, only when I go to map 15 ( detecting misfires ) is counting misfires like 1 2 3 0 1 2 3 4 5 6 0 is doing reset counting them. The rest of the cilinders are always with 0 misfires. How can i check the injector ?
    The car runs great and we did already a dyno . The car has 263 hp which is normal.
    Apr 2012
    12
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Control Module Part Number: 8P0 907 115 H HW: 8P0 907 115 B
    Component and/or Version: 2.0l R4/4V TFSI 0050
    Software Coding: 01030003180F0060
    Work Shop Code: WSC 66565 257 00032
    VCID: 37792FEF3D8D
    2 Faults Found:
    000768 - Random/Multiple Cylinder Misfire Detected
    P0300 - 008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 20910 km
    Time Indication: 0
    Date: 2012.04.27
    Time: 18:47:06
    Freeze Frame:
    RPM: 750 /min
    Load: 17.2 %
    Speed: 0.0 km/h
    Temperature: 81.0°C
    Temperature: 36.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.097 V
    000771 - Cylinder 3: Misfire Detected
    P0303 - 008 - Implausible Signal
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 20910 km
    Time Indication: 0
    Date: 2012.04.27
    Time: 18:47:23
    Freeze Frame:
    RPM: 756 /min
    Load: 16.9 %
    Speed: 0.0 km/h
    Temperature: 81.0°C
    Temperature: 36.0°C
    Voltage: 13.970 V
    Readiness: 0110 0101
    Apr 2012
    12
    Quote Originally Posted by RS3FAN View Post
    VCID: 37792FEF3D8D
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 20910 km
    Time Indication: 0
    Date: 2012.04.27
    Time: 18:47:06
    Freeze Frame:
    RPM: 750 /min
    Load: 17.2 %
    Speed: 0.0 km/h
    Temperature: 81.0°C
    Temperature: 36.0°C
    Voltage: 14.097 V
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 20910 km
    Time Indication: 0
    Date: 2012.04.27
    Time: 18:47:23
    Freeze Frame:
    RPM: 756 /min
    Load: 16.9 %
    Speed: 0.0 km/h
    Temperature: 81.0°C
    Temperature: 36.0°C
    Voltage: 13.970 V
    We didn´t yet discovered the problem, anyone with same ?
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    take it to audi an say, look, the cars only done 12k. it's mis-firing? they might out of good willl offer something. it should be as new with that mileage!
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    im sorry to say this but it looks like valve spring problem. its the exact symptoms i have. I have been tryin to get Audi to sort it for two years to no avail. My car is currently at AMD essex having them changed. Ill let you knowhow i get on.
    Im almost certain its this as all cars that were affected seem to be late 08 early 09's
    Sorry to be the bearer of bad news, i hope i'm wrong
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
  1. Misfire when cold, when warm, misfire on WOT
    By JohnDudley in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2012, 13:07
  2. Help Please - Constantly Misfire at idle on Audi A3 1.6
    By FJ0372 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2012, 21:13
  3. AUDI A3 140 TDI SERIOUS MISFIRE ! ANY SUGGESTIONS
    By hollow in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th March 2010, 21:44
  4. s4 misfire?
    By chrisadams in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th February 2010, 22:09
  5. 1.8t Misfire
    By Ewok in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th September 2008, 12:34
