Chris NottEM Tuning
    Jan 2012
    1,638
    Aftermarket Parking Sensors to OEM Parking Sensors?
    As above, can it be done?
    The ones fitted to my 2009 A3 are aftermarket and I assume the reverse light wire to function and two of the sensors have failed so would it just be better to replace the lot and go OEM?
    Not worried about the price (within reason) but is it a big task to complete? Are parts hard to find? I would prefer to use eBay as my first source.
    I have read Retrofit Rear Parking Sensors? and it seems to cover anything but has anything from 2009/10 changed since that was wrote?
    The car is a March 2009 facelift sportback Sport model.
    Thanks!
    26,777
    No aftermarket ones use reverse wire, oem uses the canbus to connect to the car, wiring isnt same at all.
    Jan 2012
    1,638
    So its a no go then Nige?
    26,777
    Thats not what I said mate, you can fit oem but not using the existing aftermarket wiring etc, I can put together a kit for you.
  1. Aftermarket parking sensors? Anyone done them?
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2011, 23:56
  2. Retro fitting OEM parking sensors?
    By Khufu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th September 2009, 20:24
  3. OEM parking sensors DIS features
    By JohnS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2009, 12:04
  4. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  5. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
