Volks AutosChris Nott
Results 1 to 8 of 8
    Aug 2008
    Manchester
    130
    TDI 170 & DPF delete = MOT pass
    Just thought i'd pass it on, mine was tested last week and passed with no problems on the smoke test. Myth = busted.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Good work mate.
    Although it will not fail on emission tests, there is talk about a visual inspection in the future, and this is where you will get failed on. But if you know a guy that does MOT's, then Happy days!
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Aug 2008
    Manchester
    130
    They'd have to take a blow torch to the DPF holder bit to check that! Plus the remap is software, so again not much to look for.
    PhilM81's Avatar
    Quattro, bring on the SNOW!
    Sep 2011
    West Mids
    82
    Quote Originally Posted by jrsteeve View Post
    JRS, where did you get your delete done? cheers.
    Aug 2011
    Sunderland
    31
    I've spoken to an MOT tester mate and the visual check is if the DPF is completely removed, i removed mine cut it open then gutted it carefully and welded it back up. it took quite a few hours as its a Quattro but is well worth it and it only cost an extra £50 on top of my custom map cost to remove the regen coding.
    Its well worth it and still looks stock unless you remove quite a bit of stuff like the driveshaft and driveshaft heat shield to see the weld.
    A3 2.0 TDI S-Line Quattro (200 bhp+) BFT tuned DPF removed.
    Audi Novice
    Mar 2009
    Suffolk
    381
    Does it make much difference to power / MPG?
    Audi Northampton, Audi Ipswich, and Audi UK are rubbish and lack the basic skills of customer service.
    Please read my posts about my experience, and I hope this helps you to make the decision not to buy an Audi 2.0 TDi 170 engine, they are not fit for purpose and the tolerance levels are a joke.
    Aug 2008
    Manchester
    130
    Quote Originally Posted by PhilM81 View Post
    Done at BVR automotive near Stafford, had a few issues with a duff sensor shortly after it was done but it's been fine now since November when it was done. The main difference is that it revs quite a bit higher (it's the s-tronic) and generally seems quite a bit quicker. Can't say i've noticed a difference in mpg, hadn't owned it long before it was deleted as the dpf blocked up about a week or 2 into ownership (duff sensors!!!!). If it helps i went from Manchester to Plymouth and back on a single tank, still had a little left too.
    The original piping/casing was kept, only the dpf removed, then welded back up so it looks standard
    Old-Boy-Racer
    Good to hear I had mine remapped by R-Tech a month ago and they did the full DPF removal (cut in half, innards removed, welded back up and replaced). Map improved it from 170 to 205 and the torque is stonking. Taking a bit of getting used to but is great fun - wheelspin in 4th in the wet if I lose concentration!
  1. 2.0 tdi quattro DPF Delete Pipe
    By Daved-and-Confused in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th February 2014, 12:59
  2. 2.0 TDI 170 CR - Remapping? DPF Delete?
    By SleeD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2011, 07:46
  3. Replies: 2
    Last Post: 15th June 2011, 16:45
  4. DPF Delete for a 170 TDI Quattro Help?
    By MOOSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2011, 18:42
  5. Will my A3 2.0 tdi pass an MOT withought fog lights?
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2011, 09:37
