1st of all Chris, thanks for the words mate, overall I was more concerned the issue was related to the work done for you, but at the end of the day with all the diagnosis with parts used, it turned out to be nothing to do with the cluster etc work, but the BT unit getting itself all confused for what seemed no reason whatsoever.
I changed many things until with some more even more extended logical thinking lol, I arrived at conclusion was BT related, luckily I had other modules to test with, got there at the end of the day.
Think was a combo of defaulting the module, recoding, completely wiping car power & then recoding gradually, then it all started working again, very weird, but also a learning exercise as always, which for me is king
Also discovered a nice product to use to grease the glovebox break element as previous ones I'd used wernt as good, works very well & we repaired the glovebox with some resin, broken by a previous person, so all in all I'm actually extremely happy we resolved all the issues for Chris
Nigel has great patience when it comes to these things!
I like to think I do lol, tbh with these jobs you cant get all flustered as thats when it all goes tits up as such, you need patience, logical thought & process of elimination, that way you are able to track down the issue/s allot easier & come to a conslusion, so for me I'm very happy we found the problem & resolved it
Just out of interest, what was the issue with the BT unit?
Just didnt like to play nicely with the cars systems for some strange reason mate, coded correctly, when you pressed PTT it used to briefly show SPEAK in dis then almost instantly show PHONE, which denoted it was getting confused, then would conctinue to show PHONE each ime it was pressed, then you'd recode or battery of & test again & would start all over, very strange indeed.
i will let Nigel explain when he sees this post
Hopefully I have lol.
I have to say placing the BT module in the footwell for me isnt a good idea, right next to the steering column aswell, hence why I always fit under the seat, safer overall.
