Results 1 to 25 of 25
    Jan 2012
    1,837
    8P A3 OEM Bluetooth 8P0 862 335 AA - Request Out Of Range
    As above.
    Using v11.11.3
    Went ahead and fitted the Audi BT module 8P0 862 335 AA in preparation for my rnse retrofit. Works perfectly with the concert headunit, makes calls, receives perfectly etc.
    I got the unit from Germany so the language it displays in the DIS is obviously in German. I want to change this to English so I went in to Module 77 - Telephone and opened up coding and changed the relevant number to English UK
    But on changing the language to english and I press Do It an error comes up
    Error 31 - Request out of range and the coding doesnt get saved.
    Any ideas? I think the below coding is correct but obviously not the German and the final coding should be 0001222
    Fossie
    Rhubarb Triangle
    3,969
    If you haven't yet done the rnse upgrade then shouldn't the second-to-last digit be '0' ? Maybe worth a try !
    When you do fit the unit then the third digit needs to be '1' to get the phonebook to show on rnse.
    Jan 2012
    1,837
    Will go out and try this now
    Jan 2012
    1,837
    Right still no good, still saying request out of range
    Fossie
    Rhubarb Triangle
    3,969
    You do have a mfsw don't you ? If not 4th digit should be '0'.
    Bit stuck apart from that - sorry mate.
    Jan 2012
    1,837
    Yep MFSW is fitted.
    Thanks anyway .. Much appreciated
    Jan 2012
    1,837
    If I change the workshop code will this do anything? Don't want to try it incase it breaks it or something
    Fossie
    Rhubarb Triangle
    3,969
    Let's see if NHN or jb0o can help with this ????
    Jan 2012
    1,837
    Hopefully!
    Still doing it this afternoon, any ideas guys?
    Fossie
    Rhubarb Triangle
    3,969
    Give it time mate - one of them will be along in due course. If not, I'll PM them next week.
    Jan 2012
    1,837
    Thanks - the unit works as it should bar not letting me change any coding at all. Even if I press Do It on the original coding it still says Request Out Of Range.
    Jan 2012
    1,837
    Dug a little deeper into this this afternoon in VCDS - Seems the unit has been flashed with the AA software so this might explain why the unit doesn't accept my coding and its not AA hardware
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    What was the p/n on the bluetooth box itself, different to AA? Ive no idea Im afraid
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    Jan 2012
    1,837
    No stickers at all apart from a small one that has 8p0 862 335 aa and SWX570 on it
    The seller has no knowledge of it being ever flashed ..
    Fossie
    Rhubarb Triangle
    3,969
    Sorry Chris but I'm not sure your module can be re-programmed ! When you say 'aa' software do you mean updated ?
    Thanks jonny for responding but sorting this is well above my pay grade !
    Jan 2012
    1,837
    I'm not sure what I mean either
    From what I can gather - the module was flashed with AA which wasn't its original (whether the difference in p/n is software or hardware I'm not sure).
    Basically the unit used to be some other revision but now it's an AA revision which someone has made it into.
    I think!
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by a6_chris View Post
    I think!
    Yeah - right !!!!!!
    Jan 2012
    1,837
    Yeah - right !!!!!!
    I think it would be easier to become fluent in german than figure this out!
    Think its time to send this back don't you think? Or could Audi do something with it?
    Jan 2012
    1,837
    Opened a dispute on eBay as the seller wont refund me as he basically says sort it yourself
    Where can I get a reliable unit from .. Ie one that allows coding!
    Buy cheap buy twice eh?
    27,126
    I have the latest genuine versions for sale, PM if interested.
    Also I replied to you on the other forum.
    Jan 2012
    1,837
    Will give you a shout when I get my money back for the current one
    I replied to you too but got most replies on here ..
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    To be honest with you the correct coding is 0001222 for a standard radio in an A3/TT/R8 with MFSW, if it doesn't accept that then it is faulty.
    Many units were reflashed, particularly to Q units, AA came out later than that but there is no reason why units could not have been reflashed to AA.
    Don't understand why the seller is being such an arse with you, did you pay with paypal?
    Jan 2012
    1,837
    Doesn't accept it at all Craig, if I even press Do It on the coding already saved it comes up Request out of range.
    Would you advise to stay away from reflashed units? Maybe I just got a bad one and thats proably why it was cheap in the first place but the advert did state it was in 100% working order .. Hmm
    As I said above, the unit works as it should, connects, rings etc but it just wont let me change the coding.
    Dunno, I opened a case with eBay yesterday and he still hasn't replied and if he doesn't within 10 days then eBay sorts it out from there. Yeah, paid with PayPal and also Buy It Now so I *should* be covered
    dramirez's Avatar
    Feb 2009
    Mexico
    27
    have you tried spanish or english? (non-UK)?
    My original BT module won't allow me to code to English, only UK-English, same error message as you.
    I was planning on asking the dealer to "upgrade" or reflash the BT unit in order to see if after that it likes the US-English option.
    Jan 2012
    1,837
    eBay decided in my favour so sending back to the seller for a refund after he didn't respond to the case.
    eBay gave me a 25% discount on postage too which was nice of them
  1. OEM BT Bluetooth
    By C17LJR in forum For Sale/Wanted - Audi Parts
    Last Post: 24th June 2011, 08:50
  2. OEM Bluetooth
    By itsmeagain in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th May 2010, 17:45
  3. Anyone with OEM bluetooth...
    By SmoothAssault in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th June 2009, 01:34
  4. Bluetooth module 8P0 862 335 N ok for 2006 RNS-E?
    By ~RS~ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th May 2009, 09:05
  5. Part No. 8P0 862 335 D Bluetooth
    By magnus911 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2007, 11:43
