Sky InsuranceChris Nott
Results 1 to 12 of 12
    Feb 2012
    31
    HELP!! H&R Springs VS H&R Cup Kit
    Hi,
    I've just put some 19" BBS CK on my S3 8P and I'm now looking to lower it slightly. Was looking to put the H&R springs on but dont know wether to change to the H&R dampers as well? They say they are matched to the springs! Is it worth spending an extra £300 over the price of the springs? I have heard the car can be a bit bouncy when you only change the springs, is this true? I'm not really looking at going down the coilover route. I'm looking to keep the ride and comfort as close to oem as possible, just want to improve the look.
    Whats everyones opinion?
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Hey
    I have 19" BBS CH on my S3 and I have had my H&R springs in since Summer 2009 with no issues. Ride is good as well as handling. Brilliant along with the h&r anti roll bars.
    However, if a shock goes, I will be buying the h&r shocks.
    Jan 2012
    469
    I put the front only Eibach springs on mine and it is a big improvement - OEM looks raised at the front for some reason. Ride quality hasn't bee affected.
    See this post for pics ... Eibach Pro front only springs on S3 - anyone?
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,289
    How many miles have your current shocks covered?
    H&R don't sell the dampers alone so it's usually worh while doing them together.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Dec 2008
    278
    I've got the H&R Cup Kit on my S3 - in terms of ride it feels more comfortable than OEM on open roads\motorways and a little firmer over potholed\typically crappy British roads. Not uncomfortable by any stretch of the imagination and the car feels altogether more composed and predictable. 25mm drop all round looks spot on to me.
    As a side note, I fitted the Whiteline Anti Lift (WALK) kit at the same time (saves getting the alignment done more than once) and love the effect that has had on the way the car behaves when burying the throttle - if you can pick one up for under £200 then I'd get that done at the same time!
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,088
    I had 18" (18x8J ET44) CK's fitted with H&R springs last year and I have to say that I wish I had just bitten the bullet and uprated the dampers at the same time. The handling is excellent, but the ride is good only if you are driving on a very flat road, ..if the road is the least bit undulating or uneven then the ride is much bouncier than in my other half's Freelander II 4x4! I also experienced some rubbing front and back, but that was remedied by removing the arch liner screws. I now have 19" MTM's fitted, which are similar spec to BBS CH's with ET50 and am planning on either fitting matched dampers to the H&R's or fitting Eibach Pro Kit along with Koni FSD's as my back can't withstand the bounce any longer, lol.
    The wheels you have fitted have an impact on how you can lower your car. What width and offset are your 19" CK's? 19x8 with offset ET44? If so, you may be struggling to lower onto them without a fair bit of rubbing, unless you go for 225/215 width tyres. For cars lowered on 19's, anything less than an offset of ET48 will require tyre width of no more than 225, to prevent rubbing. The offset on your rims means that they are another 4mm closer to the wheel arch (than ET48), but you'd probably get away with running 225's and removing the arch screws. I run 225's on mine and it handles very nicely. xx
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    Quote Originally Posted by DPM View Post
    Orange-tuning.de quoted me shocks only when I asked. Will dig out the email.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,289
    May be available direct from Germany but aren't listed in the UK.
    DPM Performance
    T: 01207 561606
    Feb 2012
    31
    Quote Originally Posted by Boydie View Post
    Hey
    Thanks Boycie. What wheels are you running?
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    I said lol BBS CH 19"
    My new S.Blue S3!!
    Feb 2012
    31
    My new S.Blue S3!!
    Oh yeah!! lol Your car looks great! You've done quite a bit!
    RicoS3's Avatar
    Sprint Blue is the new Ibis!
    Aug 2009
    Scotland
    575
    PM'd Paul.
    2010 Sprint Blue S3 Black Edition - Buckets & BBS CH Black's
    2008 Ibis White S3
    2006 Brilliant Black 2.0T S-Line Special Edition
  1. H&R Cup Lowering Springs & Shocks kit???
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th July 2011, 10:04
  2. Milltek, Autotech HPFP, H&R Springs, Sachs Performance Clutch & DMF & MORE!
    By david_phillips95 in forum For Sale/Wanted - Audi Parts
    Last Post: 21st July 2011, 11:13
  3. S3 8P H&R 25mm Cup Suspension Kit - Now Reduced
    By DPM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2010, 15:31
  4. Replies: 16
    Last Post: 9th August 2009, 14:09
  5. Any-one want a H&R Cup kit for their A3?
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2009, 19:28
