Sky InsuranceEM Tuning
Results 1 to 26 of 26
    Apr 2010
    182
    what do i need to fit.... cruise control & sat nav??
    hi all, purchased my a3 on friday and I'm wanting to add cruise control and maybe the sat nav. i currently have the audi concert cd player with bose, AUX, auto headlights & wipers and a round MFSW with driver info on the display.
    I'm going to see about getting Cruise control parts ordered this week so wondered if anyone knew the part numbers and prices for what id need?
    also what would i need to fit the sat nav unit to my A3? is there only the RNS-E or is there different models etc and whats the difference?
    thinking about getting them both and fitting myself then having them both programmed in, is here anyone local to birmingham or nottingham that could do them both for me or have an idea what sort of price I'm looking at to get them both done?
    thanks in advanced
    Dan
    Apr 2012
    31
    Quote Originally Posted by gizm0 View Post
    thanks in advanced
    Dan
    I have just done the very same things if you check out my post on cruise and sat nav help.
    The cruise kit cost me about £87 from TPS, and the RNS cost me £500 from another forum member.
    Apr 2010
    182
    thanks for that ill have a look now...
    Apr 2010
    182
    just had a look, only shows pics of yours fitted and the issues you had, not really helpful to me unfortunately as i need part numbers etc.
    was your RNS hard to fit? who did your programming for you?
    thanks
    Apr 2012
    31
    The part no. for the cruise kit i fitted to my 2010 was 8PO 054 690B if that helps.
    RNS went straight in with no coding issues at all, just fired straight up.
    Apr 2010
    182
    ok thanks for that does that code supply he stalk and the new trim?
    iv read that the RNS needs coding as it brings up a fault? the wiring for the aerial looks quite complicated on one thread i read?
    Apr 2012
    31
    Sorry i dont have the part no. for the lower trim at hand.
    Fossie
    Rhubarb Triangle
    3,961
    CC retro-fit kit part no. :- 8P0 054 690 £62.29
    Lower cowl part no. :- 8P0 953 512 A £28.68
    These are ETKA prices from a dealer. Ring Dave at Stoke Audi for discounted prices but you will have to pay postage.
    Apart from VCDS coding you will also need a 12mm spline bit to remove the steering wheel
    Apr 2010
    182
    Thanks for that mike! Appreciate it, my dads in the trade do will sort me out the bits but handy to remember in case.
    Just been reading about fitting the RNS-E and seen it mentioned about an antenna adapter, will I need one of these?
    Fossie
    Rhubarb Triangle
    3,961
    Check out this thread for CC :- Cruise Control Retrofit Guide
    Yes, you will need an antenna adapter (Fakra) because the RNSE has a twin input socket that does not fit the antenna plug. Check on ebay for supply of one - they are not expensive.
    Apr 2010
    182
    Just been reading that thread looks complicated but I imagine it should be clearer when actually doing it.
    Thanks for clearing that up for me... Just got to find a unit now lol
    Fossie
    Rhubarb Triangle
    3,961
    Apr 2010
    182
    Once again... Thanks added to watch list ready
    Any idea what sort of price I would be paying for someone to code The cruise control and rnse? Also could I fit the new stalk and use it normally just as indicator until I get it coded?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,162
    I'm in Lincoln if that helps.
    Yes new indicator portion of the stalk will still work.
    Fossie
    Rhubarb Triangle
    3,961
    Any idea what sort of price I would be paying for someone to code Borge cruise control and rnse? Also could I fit the new stalk and use it normally just as indicator until I get it coded?
    Coding for both is very simple and does not take long but you do need the specialist piece of software together with the cable.
    The CC stalk is separate from the indicator stalk.
    Apr 2010
    182
    Sorry, stupid iPhone! Edited now
    Ok great so I can fit it then sort out coding
    Thanks I'll bear that in mind of I can't find anyone closer, I'm imagining getting the coding done on both by someone else would be cheaper than buying vagcom myself?
    Fossie
    Rhubarb Triangle
    3,961
    Depends on how much you might want to use VCDS (vagcom). If you plan on doing loads of mods and checking and fixing faults then you might be better buying.
    Where are you located ?
    Apr 2010
    182
    I live Birmingham way, but work from Nottingham .
    I would like to get it but unsure wether I'll get my use out of it.
    Fossie
    Rhubarb Triangle
    3,961
    Check out VCDS user section of the forum which will give you a clue as to who can help in your area.
    26,774
    Oh you would get use out of it lol, thats the issue, once you have it, you'll want to use it more
    What year is the A3?
    Apr 2010
    182
    Yeah that's the problem, I wasn't going to touch this car lol
    Its a 2008 (57 plate) NHN you supply the vcds don't you? What's price can you do it for me and is there a version of mac or is it just windows?
    Im looking at the sat navs, what's best to get? Is it worth paying out for the led one? As iv seen one for £450 used, or should I just go for the normal one? Hoping to get one this week if possible just not sure what the differences are?
    Dan
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    You need NHN
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Apr 2010
    182
    Thanks all for your advice, iv purchased a newer LED model RNS-E and antenna adapter which should all be with me today and iv got the cruise control bits so will be fitting them the weekend all being well and hopefully be purchasing vcds tomorrow
    Apr 2010
    St Albans/Herts
    227
    Hey Mike, could you confirm the part numbers below would be the correct ones for a 2007 8P S3? I've just fitted the highline 8P0 steering control module when I fitted the FBMFSW.
    '07 Phantom Black S3
    Superchips Bluefin Stage 1
    TTRS FBMFSW
    MY11 Rear Lights
    Auto-lights/Auto-Wipers/Auto-dimming rear view mirror/CHLH retrofit
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by ADi Nuff Valves View Post
    Yep - those are the right numbers. I will however double check on latest list. Those numbers were the ones I got.
    Edit - just double checked, those are correct.
    Apr 2010
    St Albans/Herts
    227
    Great, thanks.
    TTRS FBMFSW
    MY11 Rear Lights
  1. Cruise and sat nav help
    By Dubport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2012, 18:43
  2. Cruise Control / Sat Nav S3 retrofit
    By omegadirective in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2011, 10:59
  3. Cant Fit Cruise Control to my A3
    By Symac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th May 2010, 19:03
  4. Cruise control *** How do I fit ***
    By imported_Coullio in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2005, 20:34
  5. Cruise Control Retro Fit?
    By imported_A3dude in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2005, 13:23
