AH FabricationsBadger5
Results 1 to 12 of 12
    Feb 2011
    299
    Knocking sound on full left lock
    As title, any ideas? Only started yesterday and only when on full left lock so obviously at low speeds only!
    Wanted - a pillar covers, leather interior, rear bumper, standard head lining
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,450
    ​Possible a gater issue.
    Apr 2012
    Skipton
    59
    sounds like the symptom of a driveshaft outer cv joint. Where are you located? If your anywhere near skipton in North Yorkshire we could take a look for you. If not any workshop should be able to easily diagnose the fault.
    Rob
    Feb 2011
    299
    Hmmmm really? I had the cv gaiter replaced at mot (only 6 months ago!).
    The car is quite low, would this lead to excessive gaiter wear?
    Many thanks
    Apr 2012
    Skipton
    59
    the gaiter only covers the joint. If it's the joint thats worn/ knocking that will need replacing as well. Low cars do go through C.V joints quicker than normal.
    Regards
    Rob
    Feb 2011
    299
    Ok cool many thanks will get it checked this week.
    27,089
    Also racks have been known to cause the same issue usually only on left full lock, hence audi have a plentiful supply of the buggers always.
    PhilM81's Avatar
    Quattro, bring on the SNOW!
    Sep 2011
    West Mids
    82
    Hi Ian,
    I would be interested to know if you solve this problem, I also have a vibration/knocking when turning left!
    Vibration from Front Right Wheel on a Left Turn! Driving me mad! Please Help...
    Cheers, Phil.
    27,089
    Is it on full lock?
    PhilM81's Avatar
    Sep 2011
    West Mids
    82
    Ian, did you manage to fix this??
    Feb 2011
    299
    My mechanic looked at it last week, said its the outer cv joint, getting it done this week.
    Feb 2011
    299
    Sorry that meant to say out cv joint gaiter.
  1. Clunking/knocking noise when full lock...
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2012, 08:01
  2. knocking and grinding noise on left hand bends
    By wickyianr1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th October 2010, 21:13
  3. knocking noise turning left job done
    Last Post: 12th October 2010, 20:04
  4. Knocking on full lock
    By Vorsprung_Durch_Technik in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd December 2007, 08:58
  5. Knocking sound
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2004, 19:14
