Results 1 to 11 of 11
    Apr 2010
    182
    Newbie questions bought myself an a3 8p tdi :)
    Hi all purchased myself a 2008 57plate A3 tdi 170, s line with Bose and auto lights & wipers and absolutely love it! Just got a couple of questions if anyone could be so kind to help?
    The car has the round mfsw but when I press the two inner buttons it comes up 'no function' could anyone tell me what they are supposed to do or how I get it to work?
    I want to fit cruise control but have found many conflicting opinions about what I'll need, I have the mfsw and the drivers info about mpg etc, and any idea what sort of price someone would charge to code it in for me as I can supply and fit the parts myself.
    Im also looking at fitting the sat nav (RNS-E?) but I have the audi concert cd player and haven't found much info on that retrofit to be able to tell me how hard it is to change over?
    Last question lol... Where's the cheapest place to buy vag com from so I could maybe have a go at coding myself iv been told £250 in the past and is there a mac version?
    Thanks all.
    Dan
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Hi mate, congrats on the new purchase.
    The two inner buttons are used if you have the factory fitted Bluetooth. Allows to to speak the name a dial, also allows you to scroll through phonebook and dial. If these functions do not work then I assume you don't have Bluetooth.
    With regards to cruise, then all you need, is the double stalk with cruise and new lower cowling. You already gave the right steering ecu.
    You will also need this coding.
    There are many members here who can do this install for you, including myself, NHN, j0bo, Itwasntme187 as well as others. All depending what area you are.
    Best person to contact for VCDS cable is NHN as he is the genuine stockist here, and is doing a group buy at the moment.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Apr 2010
    182
    Thanks for the speedy reply, is there any way I can find out if I have Bluetooth? How do I connect my phone? I think it's pointless Audi fitting the buttons of it doesn't work lol.
    Im from the birmingham area work Nottingham way but wouldn't mind travelling a little bit if I got someone to code it for me.
    Sounds good have you got a link to the group but please?
    Dan
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Here is a link to the group buy Vagcom.biz
    or you could just PM NHN on here.
    Best way to find out if you have Bluetooth, is to search new devices from your phone, or press the mode button on your wheel and it should come up with something like "no phone connected".
    Apr 2010
    182
    Thanks I'll look into getting vagcom then, does the group buy come with the software etc?
    The mode button just says 'no function'
    Lewbo's Avatar
    Aug 2009
    Hull
    1,061
    Does your car come with phone prep in the leather armrest or does it have the shark fin on the roof, if so you will 100% have Bluetooth, just search for it as soon as you start the car.
    Rnse is a very easy job, remove old cd player, insert rnse and plug in the leads, then code via vag com. Just need to mount the gps antenna too. Takes about 15 mins all in. With you saying you have Bose you need to change over a wire. Here is a helpful thread on the full job
    2007 S3(8P): Symphony II+ to RNS-E conversion
    Cruise is simple to fit takes around 1 hour. I have done this a few times. Also needs coding.
    Here is a very helpful guide to follow
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    Apr 2010
    182
    Yeah I read about the symphony to rnse but I have the concert and has a slightly rounded headunit is it still a straight swap? Thanks for both guides
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Just checked NHN's group but, and it seems it has ended. Sorry for this. Still contact him as his normal price is still competitive.
    Apr 2010
    182
    Ok thanks anyway, is it much effort/cost to fit Bluetooth to my a3?
    Rob2k68's Avatar
    Feb 2012
    109
    Hello and welcome to the forum.
    I see that you work in Nottingham, give ESP cars a call as they are based in Nottingham. They fitted my Bluetooth for me using all Audi parts so it is essentially as it would be if it came from the factory. Very neat job no sign of anything having being removed and no squeaks or rattles. Think it was about £350.
    Apr 2010
    182
    Ok thanks, don't think I'll et that much use out the Bluetooth to warrant spending that much on it lol definatly want the cruise control and maybe RNS-E.
    Any other little upgrades anyone can recommend?
  1. Just bought 2yr old A4 2.0 TDi Multitronic... few questions to ask
    By sid812 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 29th June 2011, 09:30
  2. Yellow a3 tdi 140 newbie. Advice and questions
    By aterro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th September 2010, 17:10
  3. Just bought an A3 1.8T few questions to ask.
    By jakesands1.8T in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2010, 20:45
  4. Just bought an S3! some questions
    By cliowilliams in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th August 2004, 11:30
  5. Just bought an 2001 S4, have some questions...
    By samuel_adam in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st May 2004, 20:30
