EM TuningBadger5
    Mar 2012
    Angry Engine management light
    Hi,
    Had the engine management light come on about 6 weeks ago on my a3 2.0 tdi s line dsg, mechanic ran a scan, intake manifold flap not opening/shutting correctly, replaced intake manifold flap (£360) Cardiff Audi, light still on !! Replaced fuse (f8) as it had blown, only knowing that from the forum so got my guy out to run another scan & reset hoping that it would stay off this time. Nope scan was saying mass air flow sensor/ signal too low !!! Replaced the maf myself and the bugger is still on, got my mechanic out again hoping that it only needed resetting. While he was there the light was out, he said that a gearbox solanoid error was the only 1 showing up on his scan, told me not to worry about it and the engine management light shouldn't come back on !!! He left, as soon as i started my car the next time the light was on again & is staying on !!! Wtf doing my head in, don't think I'm going to use the same mechanic again but need to get it sorted !!! Any ideas ????
    May 2012
    ENGINE MANAGEMENT LIGHT ON AUDI A3
    Hi, this will definately work , i hve got the same story as yours engine light come up went to mechanic, he change the throttle body for 280 pounds but the light came back on again , went back again to him and he said ohh it could be the other top part of throtle body so another 80 pounds , light went off for few hours then come back on again , so i had enough of these mechanics and there rip off prices , went to look on internet forums, some really expert and great poeple out here who knows and really willing to help for free , so i decided to to do what they said , i check the fuse next to battery compartment and its F22 FUSE FOR ENGINE COMPONENET its was gone so i change itmyself , then what i did what many have not tried yet , I HAVE UNPLUG THE BATTERY WIRES FROM THE BONNET LEAVE IT FOR 10 MINS... AND THEN PLUG IT BACK ON..... when i start the engine all the light came on ESP , STEARING WHEEL ETC BUT WHEN I START DRIVING IT WENT OFF ONE BY ONE ; AND THIS MORNING THE ENGINE MANAGEMENT LIGHT WENT OFF completley.. SO TRY THAT ; I HAVE ASKED ONE OF MY MATE AND HE SAID THIS IS A MASTER RESET ... SO CHECK THE FUSE F 22 AND THEN UNPLUG THE BATTERY WIRE FOR 10 MINS AND THEN PLUG THEM BACK AGAIN DONT worry about OF ALL THE LIGHT ALL THE CAR DOES IS READ THEM SLOWLY SO ALL OF THEM WILL GO EVENTUALLY ONE BY ONE BUT I DO RECEMMOMD TO DRIVE ONCE TO PLUG THE BATTERY WIRE BACK IN .. MANY THANKS please give me feed back if any one else tried it as really it will save you money and time and does not required ECU computer or any thing.
    kind regards
    Shuja
    May 2012
    Hi pustv , this will definately work , i hve got the same story as yours engine light come up went to mechanic, he change the throttle body for 280 pounds but the light came back on again , went back again to him and he said ohh it could be the other top part of throtle body so another 80 pounds , light went off for few hours then come back on again , so i had enough of these mechanics and there rip off prices , went to look on internet forums, some really expert and great poeple out here who knows and really willing to help for free , so i decided to to do what they said , i check the fuse next to battery compartment and its F22 FUSE FOR ENGINE COMPONENET its was gone so i change itmyself , then what i did what many have not tried yet , I HAVE UNPLUG THE BATTERY WIRES FROM THE BONNET LEAVE IT FOR 10 MINS... AND THEN PLUG IT BACK ON..... when i start the engine all the light came on ESP , STEARING WHEEL ETC BUT WHEN I START DRIVING IT WENT OFF ONE BY ONE ; AND THIS MORNING THE ENGINE MANAGEMENT LIGHT WENT OFF completley.. SO TRY THAT ; I HAVE ASKED ONE OF MY MATE AND HE SAID THIS IS A MASTER RESET ... SO CHECK THE FUSE F 22 AND THEN UNPLUG THE BATTERY WIRE FOR 10 MINS AND THEN PLUG THEM BACK AGAIN DONT worry about OF ALL THE LIGHT ALL THE CAR DOES IS READ THEM SLOWLY SO ALL OF THEM WILL GO EVENTUALLY ONE BY ONE BUT I DO RECOMMEND TO DRIVE ONCE TO PLUG THE BATTERY WIRE BACK IN .. MANY THANKS please give me feed back if any one else tried it as really it will save you money and time and does not required ECU computer or any thing.
    kind regards
    Shuja
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    clean throttle body, flush oil and replace, new filter, clear codes, throttle body adaptaition and change fuse all done
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Audi techs most of the time IMHO these days think PC diagnostics tells all. I wonder if the throttle body did need changing if a fuse had blown?
    When I disconnected battery while adding cruise control, only the 'steering wheel' light was on, which reset after turning the steering wheel lock to lock.
    P5SND suggested if was more poss a gunked up body and MAF needing cleaning.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    probably more likely siezed with todays "long life" schedules things get gunked up and the services being done are sub standard a flush should be procedure with oil change but it isnt same with a throttle body clean they keep your oil burn to a low
    Mods
  1. Coil Light Flashing & Engine Management Light
    By vik007 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2012, 19:43
  2. abs and esp light on with engine management light
    By madsad1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 18:22
  3. engine management light and traction control light always on
    By martin9k in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2010, 13:31
  4. ESP light then Engine Management light
    By V6Pete in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2010, 08:50
  5. Engine management light and ESP light on
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2005, 14:30
