Sky InsuranceVolks Autos
Results 1 to 14 of 14
    Jan 2011
    105
    Has any one had this or know what causes it?
    As the title asks really. I've had this in the carpet since I bought the car. A bit annoyed as I missed it when (not so) thoroughly checking the car over. But obviously saw it soon after! Private sale, so no recourse with a garage available.
    2007 8P S-line 140 TDI BKD Sportback. Milltek De-cat, Cat-back, AMD remap, 312mm Brake conversion, Bose, Alcantra Leather, BT, Dark Headlining, Piano black trim, courtesy light pack.
    willowsdad's Avatar
    Sideways
    Oct 2011
    Medway-Kent
    1,022
    The link won't work mate. And I'm intrigued now as to what it is!
    A3 3.2 Quattro Sport
    Jan 2011
    105
    Balls!!! I obviously didn't follow the instructions closely enough. I wouldn't hold your breath, its not that exciting!
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,793
    How do you get the pics to work
    Go to "my profile" (top right)
    Then go into your photo album and click, "upload photo"
    Select photo from your computer
    Wait for it to upload...........
    Then once its done it and its sitting in your album, it will have been given a "Picture URL" Shows it bottom right underneath the picture.
    Then go into the box where you talk to all of us lot in a thread and select the button 3rd from the right "insert image"
    That will bring up a box that awaits your Picture URL......
    I find when you have lots of pictures to put in a thread to have 2 Audisport windows open.
    So you can just copy the Picture URL and paste into the thread via that "insert image button" saves you going backwards and forwards.
    Thats how i do it anyway! works fine!
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,483
    I use imageshack, its easy to use.
    Jan 2011
    105
    YAY!!!! My Pic cherry has been popped. Thanks for all your help. I decided on FlickR before I read the last two posts, so have gone down that route.
    Jan 2011
    105
    Jan 2012
    1,837
    Looks like mould but I'm viewing on my iPhone so it looks smaller than it is.
    Im sure a good wet vac would sort that out.
    Aug 2008
    408
    Also viewing via phone, it looks like road salt
    Cal
    Gryphon001's Avatar
    Jun 2009
    303
    Wow... I can see none of you live in Canada... lol
    Looks like road salt. There is a special cleaner for removing salt deposits from carpets... But a bit of hot water, steam cleaner and a lot of effort if they are hard. Mine last year were half a cm thick in places.
    Jan 2011
    105
    The pic was taken on my Iphone, and clearly isn't that good! The white area is not on the carpet, its where the carpet pile has come out of the backing, and left nothing else but that backing!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    you sure ist not just salt intrusion
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Gryphon001's Avatar
    Jun 2009
    303
    If it is the carpet pile coming out, something corrosive was spilled... At which point I'd check the floor from underneath.
    Jan 2011
    105
    I've heard of a recall on the A4's that changed the drain pipe for the bulkhead/heater system/pollen filter area because it was letting in water, and that caused the carpet to rot from underneath and the pile to then come out. Unfortunately the carpet isn't wet at all, so I don't think that's it!
