    Dec 2011
    11
    PCV delete DIY cost<10£
    What do you think about this simple fix instead of spending money on a block of PCV plate?
    http://forums.vwvortex.com/showthrea...1#post75296241
    I have actually been thinking about doing it before finding this link and seeing that someone actually has done it. But naturally i would like to ensure the mod will work the same way as the block off plate does.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Not sure I'd like to drive around with excess +ve pressure in the crank case engine.
    Why not simply cut the pipe and put a blank inbetween, then hose clip in place. That'll save using 2 extra clips.
    One thing I noticed was the guy used a screw driver to remove the plastic hoses's clips. All that's required is to squeeze the clips.
    I did my own PCV fix buying a metal body double check valve for £15. After 4 years it's still 100%.
    Easy to check vacuum and boost with the boost gauge installed on dash.
    Dec 2011
    11
    According to below link it should not be a issue:
    The Ultimate 2.0T PCV Fix | DEVIANT:SPEED
    Further input and comments are welcome.
  1. A4 170TDI DPF delete and remap - cost?
    By eddscott in forum Sales Questions
    Last Post: 12th April 2012, 14:40
  2. DIY optics grill at a fraction of the cost of a new one.
    By mx_rab in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th March 2012, 23:11
  3. SAI/N249/EVAP Delete and PCV Simplified. Pro's and Con's?
    By Craig1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2012, 13:05
  4. Replies: 3
    Last Post: 15th November 2010, 22:58
  5. Replies: 3
    Last Post: 31st October 2010, 09:31
