Chris NottAH Fabrications
    Apr 2012
    A3 54 Plate 2.0 Diesel with Rough Idle - Help!!!?
    Hi Guys,
    I just got an 54 plate A3 with a rough idle when stood at the lights. It disappears when the air con is on high and the load on engine rises.
    Anyone near Leeds that would be able to help in return for a few quid?
    Si
    tdi-man's Avatar
    Jul 2009
    1,588
    search on here m8 for idle theres lots of possibles but i would say get timing checked properly by someone that knows whar there doing.
    welcome to the site
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    Apr 2012
    Cheers mate - will do.
    It was ok when I took for test drive but before collection they did the cam/timing belt service and seems to have caused this.
    I had an A3 previously and I appreciate most are hardly delicate when they idle but this one is awful.
    Si
    Apr 2012
    Bit of an update.
    I know some bloke through the gym who works for Audi and he quickly connected his laptop with VAG software. He said no fault codes, no misfire and timing all ok.
    That is all a relief but does not explain the intermittent stange up and down engine tone when at idle.
    Annoyingly it did not do it when he was taking a look
    tdi-man's Avatar
    Jul 2009
    1,588
    you cant check the rear cam shaft timing with vag com.
  1. B5 S4 rough idle
    By S4_Biturb in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2012, 14:13
  2. Rough idle really rough
    By audiv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2011, 15:33
  3. rough idle
    By simon1303 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2010, 16:24
  4. Rough Idle
    By RobbieL in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2008, 10:47
  5. Rough Idle
    By ad3crk in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2006, 09:52
