Sky InsuranceEM Tuning
    Feb 2012
    38
    New head ordered what gasket is needed ?
    ive ordered a amc head for my bkd engine and ive got a choice of three head gaskets being : 1.5mm 1.63 and 1.71 being a new head what gasket would i be best running ?
    Viking's Avatar
    Mar 2010
    215
    The thickness of the gasket determines the compression ratio, so your gasket choice is governed by that. If you're after standard compression ratio then there's a calculation based on the protrusion of the pistons above the top of the bores, but that would equate to a genuine OEM head. I've no knowledge of AMC heads and what they're like in comparison to the OEM, so maybe AMC would advise?
  1. Possible Head Gasket / Cracked Head Problem?
    By Wabby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th February 2013, 14:31
  2. Head gasket has gone:(
    By Sandip in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2010, 12:22
  3. S3 Head gasket
    By fluffsri in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2010, 19:50
  4. Head gasket/ cylinder head worst nightmare!
    By lugz in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2010, 15:52
  5. Head Gasket
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2009, 14:32
