Badger5Volks Autos
    ilim's Avatar
    Nov 2011
    632
    Forge Twin take.
    Quick question. Can a Forge Twin take from a golf TFSi fit a S3 tfsi 2011??
    ilim
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,087
    According to the Forge Motorsport website, there are many different versions of the Twintake, each specific to a particular model of car, so it doesn't look like you can mix and match them, unfortunately xx
    This is copied from their site -
    However, every version of our Twintake kits are different in some way and are specific to one vehicle model. The kits are not interchangeable and we do not sell the components separately. If you are in doubt as to which kit is required please follow this guide.
    1.Determine manufacturer – Audi, SEAT or VW
    2. Determine model - so for a VW Golf this could be Golf MK5 or Golf MK6
    3. Determine Engine – All our Twintakes are for the 2 litre VAG group petrol engines only. The earlier engine was found in the MK5 Golf, badged as the FSi in the UK market, and easily distinguished as it incorporated the air filter in the engine cover. The later engine, badged in the UK as TSi, is found in some MK5 Golfs, all MK6 Golfs and is easily distinguished as the OEM air filter box is separate from the engine cover.
    4. Double check your MAF sensor part number. Since 2009 the VW/Audi gorup have been changing the MAF sensors on their cars to a 'more advanced' sensor which resists tuning and has the mounting plate mounted 180 degrees rotated from the original. However, many cars produced since 2009 still have the old sensor. Please check the picture below to make sure you have the correct MAF sensor - the part number is printed in white on the top. We currently have no solution for the new MAF sensor on any car.
    Vehicles / Twintake part numbers
    Audi S3 with OEM air filter built into engine cover – Pt No.FMIND12E
    Audi A3 with OEM air filter built into engine cover – Pt No.FMIND12G (coming soon)
    Audi A3 with OEM air filter separate from engine cover – Pt No.FMIND12H (coming soon)
    SEAT Leon Cupra with OEM air filter built into engine cover – Pt No.FMIND12D
    SEAT Leon (not Cupra) with OEM air filter incorporated into engine cover – Pt No.FMIND12F
    VW MK5 Golf with OEM air filter built into engine cover ie BPY engines (2005-8 in USA or 2005-9 in UK) – Pt No.FMIND12
    VW MK5 Golf ED30 with OEM air filter built into engine cover – Pt No.FMIND12B
    VW MK5 Golf with OEM air filter separate from engine cover (CCTA 2008 on in USA ) – Pt No.FMIND12A
    VW MK5 Golf with OEM air filter separate from engine cover (CBFA) Pt No. FMIND12A and FMFIL28**
    VW MK6 Golf (USA only *) with OEM air filter separate from engine cover – Pt No.FMIND12J
    VW Scirocco R with OEM air filter incorporated into engine cover – Pt No.FMIND12K
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    ilim's Avatar
    Nov 2011
    632
    Quote Originally Posted by Paullie View Post
    Cheers paullie had a mate that was selling one, so though i would ask before i did something stupid....
    rodaz's Avatar
    Jan 2012
    13
    DOES NOT FIT!
    Yuo can take one out of a Seat Leon Cupra - but the side Filter sheet does not fit
    09 S3 / Eibach Pro Kit, PCV Fix, Forge Twintake, TTS engine cover, Sachs clutch with LOBA one mass fly wheel, rear camera, etc
  1. ITG or Forge twin intake
    By kevsin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th August 2012, 21:51
  2. Replies: 22
    Last Post: 6th July 2010, 21:24
  3. Update! Forge Twin Take
    By gaz m in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2010, 16:37
  4. Anyone fancy swapping their Forge 007p for my Forge SplitR?
    By Az in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2009, 12:56
  5. Twin twin exhaust
    By dc240969 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2008, 00:42
