EM TuningSky Insurance
Results 1 to 8 of 8
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    A3 2.0tdi water pump
    My friend is changing his cam belt and thought he'd do the water pump while he's there. He's read some where that you need to pressurise the water system and keep it pressurised. Is this true and how are you meant to do that?
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Mar 2011
    Cleveland
    979
    Duh? You have to drain the water, so how can you keep it pressurised? When the pump comes out, there's a great big hole in the cooling system!
    Mar 2011
    Dumfries and Galloway
    148
    Ooooo good come back hahaha personally have no idea what your friendhas been reading. If this is true though i would like to know how its done.
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    I doesn't make sense to me but he asked me to ask anyway. Might you have to pressurise it afterwards, I'm guessing to test for leaks?
    PS3: Broady_11
    Mar 2011
    148
    Well being a pump it will pressurise the system itself once the engine is running.
    Sportback owner
    Apr 2007
    France
    492
    No MX, the pump only circulates the water around this closed system. The pressure comes from the water being heated up, and expanding. Excess water ends up in the header tank. Max pressure is reached just after turning off the engine. Since the block is still very hot, and there is no cooling by the radiator, then for a few minutes at least the temperature/pressure may rise. That will be max pressure and that is the time to look for any external leaks. Anyway, make sure your friend puts the recommended coolant into the system and not plain water.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Apr 2012
    59
    your friend is changing his cambelt?? and is asking how to keep the water system pressurised with a big hole where the pump should go ?????
    sounds like a recipe for disaster.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by scotty2hotty View Post
    Spot-on ! His friend doesn't have a clue and should definitely not be messing about with the cambelt.
  1. 2.0TDI Cambelt + Water Pump Service
    By A3chase in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2010, 09:33
  2. Water pump gone?
    By rolphy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2010, 18:41
  3. Water pump
    By os360 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2008, 19:38
  4. Water Pump
    By S3 NIK in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2007, 21:23
  5. Water pump
    By johnie72 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2007, 21:41
