Sky InsuranceVolks Autos
Results 1 to 18 of 18
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Xenon Range Control Fault ~ Scary
    My 3+ yr car's got Xenon adaptive lights.
    The xenon range control warning light flashed up intermittently twice today.
    1st time it happened was about 3 weeks ago. Even after that, VCDS recorded no fault.
    Yesterday, swapped the wheels around, front to back. This afternoon, lighting switch set to auto, range control warning flashed up after about 12miles on the road.
    Switched off the engine will stationary at lights. Fault cleared only to come on again 2 miles later.
    I'm guessing it's a loose connection issue.
    Suggestions what to look for.
    Any one got picks of the suspension sensor/s and or connectors?
    27,108
    Check the levelling sensors on front/rear passenger side axle.
    Ideally needs a scan.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Okay took a scan..
    Something else is crazy.. mileage reads +1million Km!
    It says fault frequency 1 but it happened 2 times.
    Which front sensor is 00496?
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Control Module Part Number: 4L0 910 357 HW: 4L0 907 357
    Component and/or Version: AFS 1 H01 0040
    Software Coding: 0000028
    Work Shop Code: WSC 06314 000 00000
    Additional Info: 7L6941329B AFS-Modul links H03 S004 7L6941329B AFS-Modul rechtsH03 S004
    VCID: E9D2A697C062431
    1 Fault Found:
    00496 - Sensor for Vehicle Leveling; Front
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 1048575 km
    Time Indication: 0
    Nov 2005
    UK
    586
    When mine did this, they had to slightly move the connector box that sits behind the glove box, as it had moved and was pulling on the connecting wires, making this exact intermittent fault......may be worth a look ?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Ta for help lads.
    I'll check it out at the weekend. Hopefully weather will be more sociable by then.
    27,108
    Well, its pointing to a sensor, the levelling controller as mentioned before should have plenty of slack, but feel free to check.
    Have you lowered the car as sometimes sensors get buggered when messing with suspension.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Ta for the help.
    Nope.. car's on standard suspension and tyres.
    All that was done recently was to swap the wheels around.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Out and about today, warning light came on.
    While under the car later in the day, seems only one sensor, on the front, in the nearside location
    Connector was clean. Twiddled the ball joints and gave them a spray with silicone.
    After checking retrofited cruise control (which worked 100%), no headlight warning light.
    Time will tell, as this is an intermittent issue.
    The Governor's Avatar
    Mar 2012
    Southampton
    436
    Sorry to thread hijack, but what exactly does the range control do anyway?
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    when your climb a hil your height of your headlights is adjusted by the car to compensate for loss of vision and to prevent getting in other road users eyes
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Based on the ride height of the car i.e. laden with people/luggage or dipping due to road conditions, it automatically adjusts the beam height to keep it at optimum setting and stop dazzling oncoming drivers.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Warning light now permanently on. VCDS measuring block channel 002 reads 0.0 deg Front. -10.0 deg Rear, Voltage 4.6
    When I took off the front sensor to give it a lube and workout, reading stuck at 54deg. Since then it's rest to 0.0 deg.
    Headlight motors seem to adjust lights when initially switched on.
    27,108
    What you should do is remove the sensor from the axle & move it up & down & see if the MVB for that sensor changes readings, if not then it would indicate 1 of several things, wiring, sensor buggered or levelling controller faulty, so you need to research it properly to find the issue, I would remove the rear sensor aswell & swap round & manually test moving up/down, that should hopefully help with your analysis.
    Zak0123's Avatar
    Apr 2012
    Cambridgeshire
    459
    Sorry to hijack this post, NHN got your PM but can't reply until 15 posts I don't think so will reply as soon as I can! Thanks man!!
    Brilliant Black 61 Plate A3 1.6 TDI
    Mods: S3 BE 5 Spoke Rotor Wheels with Goodyear EfficientGrip
    , AppRadio 2, 80% tints, Diamond Vision Headlights
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Thanks for the advice.
    I did try that. Reading did not change. Plus wiggled the cable.
    Cable looks ok, as are all wires connected under the connector's rubber boot.
    I'm suspecting it's the sensor as this is the wheel which I found to be buckled a week or so ago. Which I'm sure the previous owner did.
    27,108
    So you've tested the rear sensor readings?
    Have you plugged the rear sensor into the front connector to see if it shows readings then & vice versa, dont need to bolt it to the underside, just move manually whilst its loose.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    No I have not done that.
    But I shall follow your advice and do so later in the week and report back.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Got it sorted under a WarrantyWise Policy. Was tired of seeing the yellow warning icon on the DIS. Now lights have started to swivel again when cornering.
    Used a local Audi indy, who I must say gave 5star service which IMHO beats a main dealer. Total came to £168 for the front sensor incl about 50mins labour.
    I'm well happy to take my car there for any future work, which says a lot from fussy me.
    Oh did I say they fitted the work in, within 3 days, compared to local Audi dealer's 2 weeks !!!
    NHN, my VCDS pre-scan showed they did as you suggested with the sensor swap to see if it was sensor and or wiring.
  1. A3 8P Headlight Range Control Defective / turn this off / can I code xenon to halogen
    By thebedscompany in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2012, 17:12
  2. xenon range faulty
    By Ianmanchester in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd November 2008, 15:54
  3. 2001 A3 (8L) Xenon range problem
    By sjokolademelka in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th June 2008, 12:52
  4. XENON HID H1 KIT TOP OF THE RANGE
    By rallyingarron in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th September 2007, 17:56
  5. Xenon Lights Range
    By tonedef in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th October 2006, 11:11
