Badger5Sky Insurance
Page 2 of 2 FirstFirst 12
Results 41 to 47 of 47
  1. #41
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,426
    Quote Originally Posted by Tortel View Post
    Nice to hear that! Can you make it oversteer using the trottle? With the stage2+ is quite complicated unless the tarmac is wet (I have the Haldex controller too ) I am thinking about upgrading the turbo of my S3, but I am a bit concerned as I do an important milleage...
    I do about 14 000 miles a year,and it has to be totally reliable,so it's been built with that in mind,and hasn't disappointed so far.
    Oversteer is easy enough,and even in a straight line on a dry road the TC will come on up to 3rd gear,until the tyres are really hot....the amount of torque now is crazy compared to before,but part of the point behind an overkill clutch was for some future increases.
  3. #42
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    What power you running then S3Alex?
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
  4. #43
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,426
    Quote Originally Posted by devonmikeyboy View Post
    All I've got right now is that the dyno crapped out at 480bhp with a fair bit more to go.
    There was some issue with the dyno which we couldn't reproduce on the road,where the ECU was pulling load and timing,which it doesn't do on the road at full throttle,and part of it seemed down to the Haldex,but what I do need to do is to run it on an eddy current dyno instead.
    We do know from another car running the exact same setup but MINUS water/meth,that 2bar equates to around 520bhp.
    However,given that it's a lot faster than it's previous runs at 1.7bar and 480bhp,and now runs 2bar,it's in the 500bhp ball-park somewhere.
  5. #44
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,553
    Wow alex thats great news 500 bhp ,did you sort out the tc ..
  6. #45
    Feb 2007
    1,257
    Same power range as my R32 then. If you want to try some road legal track tyres ( Toyo R888, Federal 595RS-R etc ) i have several new and used for sale that will sort out your traction issue.
  7. #46
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,426
    That's very kind.
    Thank you!
    Are the R888s a lot better than the R1Rs?
  8. #47
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,426
    Quote Originally Posted by s3kel View Post
    It's purely down to torque overcoming grip on cold tyres(the R1Rs) or inadequate tyres(the PS3s),but right now,the rain is sufficient to slow me down anyway!
    Mikey has very kindly offered a set of R888s,but I may have to wait until the floods recede.
  1. stage 2 2.0T clutch slip..!
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th December 2012, 18:34
  2. stage 2/3 clutch needed
    By bez101 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd January 2011, 22:52
  3. Review: Spec Stage 3+ Clutch
    By Tortel in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2010, 16:24
  4. My Spec Stage 3+ Clutch for S3
    Last Post: 17th December 2010, 09:09
  5. REVO STAGE 1 = NEW CLUTCH?
    By nealjohns in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2010, 15:40
