Badger5EM Tuning
    Dec 2009
    37
    Outside Temp Sensor
    Hi Guys,
    Over the last couple of days the outside temperature on my 2004 Audi A4 2.0TDi has been showing between -20c and -5c
    I know its cold outside but not quite that bad!
    Does anyone know where the sensor is located as I want to check its not just loose wires before I replace the part. Was working fine before the weekend.
    Jay
    27,085
    On the front left fixed to a piece of plastic behind the grill.
  1. Temp Guage not working - coolant temp sensor changed... now what?
    By car4kids in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2012, 19:10
  2. Is the coolant temp sensor plug the same as the coolant temp sender?
    By drfeelgood in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2010, 07:54
  3. Brakelight sensor + collant temp sensor
    By womb raider in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2010, 21:38
  4. temp sensor?
    By mike1234 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th December 2007, 19:42
  5. temp sensor
    By dummi in forum General Technical / How To
    Last Post: 23rd October 2004, 18:10
