EM TuningJMB Retrofits
    Apr 2012
    6
    Question Drive Shaft HELP!!
    Hi,
    I'm new here and recently purchased a 2004 2.0 tdi which I am planning to modify slightly. Bought some coilovers, fitted the rears fine, came to fitting the fronts and whilst getting carried away trying to remove the strut from the retaining collar i accidently popped the inner drive shaft out of place, i can feel the balls and cage are out of place. Can i just push this back in to place or have i got to take it all off now?
    Any help much appreciated, Thanks
    Sam
    27,129
    Depends on the shaft end fixing, I suspect its a tripodic bearing part on end, this should just push back in, I would check if it is this type that has a kind of bearing ring on a triangle kind of end of the shaft that pushes back into the housing on the drivetrain side, whatever you do, dont damage them or you'll get vibration & bad alignment as such.
  1. drive shaft
    By renton in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2011, 21:26
  2. drive shaft noise
    By oldskoolcool in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2010, 17:02
  3. DRIVE SHAFT
    By j4g3d in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2007, 17:43
  4. drive shaft fooked....
    Last Post: 18th February 2007, 00:25
  5. S4 Prop/Drive Shaft?
    By Phantom_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2006, 16:35
