JMB RetrofitsChris Nott
    Apr 2012
    24
    New Member help needed Brake discs size A3 1.9tdie 2007
    Hi all.
    New member here, not long had my first audi an A3 5dr 1.9tdie 2007 and i am having a few problems trying
    to determine the rear brake disc size. The outer edge of my disc looks like its not being touched by any pad so is rusting and
    coming apart. I have searched the web and i am getting mixed results from 232mm, 255mm and bigger.
    Any help would be appreciated.
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Neil Ashton View Post
    Hi all.
    Need your VIN to be certain. However, I have never had a car where the brake disc is completely covered by the pad. When you say coming apart, do you mean a bit of rust ? If so then no problem, that is normal.
    Apr 2012
    24
    On the edge of the disc rust has formed and the face of the discs is coming off.
    Fossie
    Rhubarb Triangle
    3,969
    In the inside cover of your service book you will have a load of PR numbers and you will have one that is 1K? (D,Q,Z etc.)
    Which one is it ?
    Apr 2012
    24
    1kd
    Fossie
    Rhubarb Triangle
    3,969
    253 x 10mm part number 1K0 615 601 AB £35.81 each
  1. Can anyone tell me what size rear brake discs I have?
    By _G_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2011, 07:33
  2. size of discs
    By DEEJAY TQS in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd August 2009, 19:35
  3. Where to get discs for Brembo's? and what size needed etc?
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2009, 17:07
  4. Brake discs incorrect size?!!!!!
    By Marko in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2007, 19:36
  5. Correct size brake discs for A3 TDI
    By f13ldy in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2005, 13:34
